Help with F18D Yanmar
/ Help with F18D Yanmar #1
jsimmo2005
joppa,al
Yanmar F18D
I have owned several years and really been a great one. I always keep the services up, well here's my problem. I put it up in the barn for the winter and took it out and it didn't really want to run right. The PTO and all hydraulics work as should. I replaced the hydraulic filter screw-on as well as the screen filter and put in all new fluid and still not working right. The problem is it is a hydrastatic and when I put it in gear to go it will rev up but will not pull or if so extremely slow, in any gears.
I would appreciate any help you can give me with this, i am pretty handy but this has me stumped. Thanks in advance for your help. Stumped in Alabama.
Jerry
/ Help with F18D Yanmar #2
does this tractor have power shift ? If so ,Is it possible you got some trash in the power shift system / circuit ?
It does but i dont know how to check this system, i do know since i've owned it new/used the shifter 1-3 and R has been stiff but never had any problems. I am in joppa, al and appreciate your help, just trying to get this figured out so i can get my chores done and garden in.
/ Help with F18D Yanmar #5
I have no idea if the transmissions are similar, but my 276D did the same thing. It turned out to be a broken spring. On mine, I removed the block that mounts on top of the transmission. I removed a plunger type thing and there was a broken spring inside. The block is easily removed, so it might be worth a look.
/ Help with F18D Yanmar #6
I'm with Winston and Silvertramp if they are the same. But I would tend to believe this maybe a good parts tractor. Esp. close to you as it is and being a"D". The owner may have some info on the Fx series that may help. It a beauty.....LOL.
Yanmar fx22d 4 x 4
Thanks for all of the help and for all who responded, i will definitely be looking at the spring, thanks.
Can anyone tell me possibly where this spring will be located on my F18D tractor, that will definitely be where i look first, thanks. a visual would be great and again thanks for all the helpful comments.
Can anyone please send me a diagram of where the powershift relief valve spring should be on my tractor, F18D , i have a manual but recently moved and can't locate it, any help is very much appreciated.
/ Help with F18D Yanmar #10
Been looking all over for you.... This is the best I can do, this is on a ym336d w/powershift, should be similar, give this post a try & hopefully it will lead you on the correct path.
http://www.tractorbynet.com/forums/yanmar/322696-new-ym336d-problem.html
/ Help with F18D Yanmar #12
Yanmar fx22d 4 x 4
That is a brilliant ad for the FX22D!
Not one tyre matches the other. :thumbsup:
/ Help with F18D Yanmar #14
#2. This is an from FX24D manual. I think yours will be the same.
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2018 RoGator 1100C (A63689)
2018 RoGator 1100C...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
55 Gallon, Mobile 46 Hydraulic Oil (A62679)
55 Gallon, Mobile...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
White Oak Slabs (A65640)
White Oak Slabs...
