Help with F18D Yanmar
/ Help with F18D Yanmar #1
jsimmo2005
joppa,al
Yanmar F18D
I have owned several years and really been a great one. I always keep the services up, well here's my problem. I put it up in the barn for the winter and took it out and it didn't really want to run right. The PTO and all hydraulics work as should. I replaced the hydraulic filter screw-on as well as the screen filter and put in all new fluid and still not working right. The problem is it is a hydrastatic and when I put it in gear to go it will rev up but will not pull or if so extremely slow, in any gears.
I would appreciate any help you can give me with this, i am pretty handy but this has me stumped. Thanks in advance for your help. Stumped in Alabama.
Jerry
/ Help with F18D Yanmar #2
does this tractor have power shift ? If so ,Is it possible you got some trash in the power shift system / circuit ?
It does but i dont know how to check this system, i do know since i've owned it new/used the shifter 1-3 and R has been stiff but never had any problems. I am in joppa, al and appreciate your help, just trying to get this figured out so i can get my chores done and garden in.
/ Help with F18D Yanmar #5
I have no idea if the transmissions are similar, but my 276D did the same thing. It turned out to be a broken spring. On mine, I removed the block that mounts on top of the transmission. I removed a plunger type thing and there was a broken spring inside. The block is easily removed, so it might be worth a look.
/ Help with F18D Yanmar #6
I'm with Winston and Silvertramp if they are the same. But I would tend to believe this maybe a good parts tractor. Esp. close to you as it is and being a"D". The owner may have some info on the Fx series that may help. It a beauty.....LOL.
Yanmar fx22d 4 x 4
Thanks for all of the help and for all who responded, i will definitely be looking at the spring, thanks.
Can anyone tell me possibly where this spring will be located on my F18D tractor, that will definitely be where i look first, thanks. a visual would be great and again thanks for all the helpful comments.
Can anyone please send me a diagram of where the powershift relief valve spring should be on my tractor, F18D , i have a manual but recently moved and can't locate it, any help is very much appreciated.
/ Help with F18D Yanmar #10
Been looking all over for you.... This is the best I can do, this is on a ym336d w/powershift, should be similar, give this post a try & hopefully it will lead you on the correct path.
http://www.tractorbynet.com/forums/yanmar/322696-new-ym336d-problem.html
/ Help with F18D Yanmar #12
Yanmar fx22d 4 x 4
That is a brilliant ad for the FX22D!
Not one tyre matches the other. :thumbsup:
/ Help with F18D Yanmar #14
#2. This is an from FX24D manual. I think yours will be the same.
Takeuchi TB225 (A62177)
Takeuchi TB225...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
EZ-Go Golf Cart (A65579)
EZ-Go Golf Cart...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
