Ford 1620 No power
/ Ford 1620 No power #1
DUHHUH
NC
Ford John deere
Do you have to purge the hydraulic system on a Ford 1620 to release any air?
I have recently bought two Ford 1620 tractors in hopes to piece them together to make one good tractor. Both tractors have been mostly taken apart and all fluids have been drained, I have assembled one tractor and was able to get it started but it has no power. When first started I can usually lift the 3 point hitch once but then it struggles to do so again. I can then put it in gear and the tractor moves about 1/2 inch. Then nothing at all.
I have jacked up the rear end and put it on jack stands. "Sometimes" when I put it in gear I can get the tires to spin both forward and reverse obviously under no load and when it is off the ground and "sometimes" they will not spin at all.
/ Ford 1620 No power #2
Hydraulic problems could be pump or bypass valve. Drivetrain problems sound like bad clutch.
/ Ford 1620 No power #3
no expert here, but in a car it usually drive fluid.
/ Ford 1620 No power #4
Check to see if you knocked the range selector out of gear. High, medium or Low. Sound like you might have just moved it enough not to catch.
Where is the bypass valve located? Also do you know if the ford 1620 has any kind of pickup screen?
the dipstick shows the correct fluid level. I have switched between all gears "L,M,H" and get the same results.
/ Ford 1620 No power #7
If it's the same as my 1920 then no screen. The 1920 has a hydro filter. Does the 1620 have a filter.
Yes the 1620 also has a hydro filter.
I will look into these. Thanks for the input
Turned out to be a clogged filter. Everything works great now.
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
iDrive TDS-2010H...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
17102 (A56859)
17102 (A56859)
Takeuchi 14.9 Yard Skid Steer Bucket Attachment with Teeth (A59228)
Takeuchi 14.9 Yard...
