Bobcat 753 Arm Lift Problems
/ Bobcat 753 Arm Lift Problems
Picked up the cylinder yesterday afternoon. The mech cleaned up the end threads of the rod. He fabricated a plug that covered the piston hole. He then used 160+ PSI of air to push the piston out of the cylinder. He cleaned everything up, locked tight'd the rod end nut and resealed. $150 for 2 hrs of labor and seals.
I bring it home, look on my work bench and realize in my haste to get the cylinder to the shop before they closed on Monday I forgot to include the rod bushing that goes between the piston and the gland $@#!@$!# !!!!!! I pulled the cylinder back apart Installed the bushing and resealed. Put both cylinders back together (the right cylinder was fine). Started the Bobcat up! Lift works 5.0!
Thanks Dennis for the help. Hope these posts save time for some poor soul out there!
/ Bobcat 753 Arm Lift Problems #22
Im thinking load check valve. Not a hard repair , just money
Dustin,
The nut on the left life cylinder piston came off. Fluid was bypassing the piston leading to loss of system pressure.
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2008 UNKNOWN SPOOL TRAILER (A60736)
2008 UNKNOWN SPOOL...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
