KUBOTA L3800 log trailer sizing
   / KUBOTA L3800 log trailer sizing #11
You could buy a winch for your current tractor, then fab up a log trailer on a hay wagon running gear or a flatbed trailer. You could then purchase a piece of old iron like a big old JD or international tractor to pull the wagon. You'd still come in well under the price of a winch and log trailer I'd think. And when you get your Kubota stuck you'll have something to pull it out with.
   / KUBOTA L3800 log trailer sizing #12
I used a wallenstein log grapple trailer behind a kubota b7800 and b3200. It was the smaller of the wallenstein models. 9.5 foot reach and 800lbs lift. It had surge brakes and hydraulic slidding tandem axel. It would pick up 6ft to 10ft logs (up to 12ft if diameter was smaller). The trailer itself was build well. Both 3500lb tractors did "ok" with it loaded on steep Pennsylvania logging roads hauling about a "face cord". The brakes on trailer were what held it back from pushing the tractors out of control, so some sort of trailer brakes are a must if you on any steep roads.
here is my opinion on any smaller log grapple trailer. The wallenstein (canadian) was built real well. But. It was way too slow, too small, and a lot of extra work well beyond what it is worth to me. If you have time to mess around, then they will work. More like for someone who has all day to do something. Mine was way too small to be efficient in my fire wood business. I spent more time positioning the trailer to reach the logs, then due to short reach had to keep repositioning to get full load. All the time I spent monkeying around with that trailer, I could have just skidded twice as much to the landing. Now a large grapple trailer with long reach I could see being effective, but you ain't hauling that size behind a 38hp tractor. Maybe a 80hp tractor.
I understand you want one to load logs, and it will do that if you can afford one ( around $18000 usd at the cheap end) and provided you have the time to spend "monkeying" around with its time consuming loading and unloading tendancies.
I sold mine and glad I did. I just skid out with my 3ph winch now with my 50hp tractor. As a note, I do fight mud on my logs, but I perfer dealing with a little mud then going back to that grapple trailer. But that is me and my situation. Like I said, they will do what you want if you got the time and cash. Wallenstein makes a good one and I think there is a medivic brand as well both canadian. The wallenstein is built well and I think your 38hp tractor could handle the smaller one. Make sure it has brakes! Good luck with your decision and stay safe.
Well, there is something bringing me back to those trailers constantly but I never pulled the trigger on it yet. Each time I think about it and ask advices, I receive mixed feeling about it. It becomes obvious that:
- I need a winch to bring what it is I want out of the wood, and,
- something to bring this from the wood to wherever it needs to be. And this could be log trailer or something else ( maybe that same whinch ).
Assuming I am convinced, which I almost am, would my tractor be a good fit to skid logs with a whinch or its on the too small side again ?
Is skidding logs with a good winch with this tractor a safer project than using a log trailer that's probably to heavy ?
Thanks again
   / KUBOTA L3800 log trailer sizing #14
Thanks again
You have not told us how big your wood is. Is it 30" diameter hard maple or oak for saw logs or much smaller/lighter wood. It makes all the difference in weather your tractor is to small. To give you an example my tractor is about the same size as yours. Slightly less hp but heavy for it's size at 5000 lbs. Weight is your friend in the woods. I handle wood like this day in and day out.
Now here is some wood that I can or did handle but it is really to big for my tractor. If I was going to work this size wood all the time I would need a bigger tractor.
A to heavy trailer is definitely more dangerous in my opinion.
gg
   / KUBOTA L3800 log trailer sizing #15
+1 ^^^
Thanks gentlemen,
Good material to chew and inspiring pictures !!
Regards,
   / KUBOTA L3800 log trailer sizing #17
I agree with Gorgon about having too big of a log behind the winch being far preferable to having too large of a trailer. The log you can lower to the ground and it will slow down most of the time.
On the topic of using one tractor to load and then pull a trailer, I moved about 9 cords this winter that way. I have a 22' deckover trailer that i pulled down the road with my Kubota. I mounted a receiver hitch to my farmi 351. When I got to my destination, I chocked the wheels, then lowered the winch so the jack hit the ground. Then I loaded the trailer, and backed the ball under the hitch. Lift the winch, pull the chocks, and you're ready to go. Never had to mess with the jack. Did have to load the trailer carefully, though. rps20170410_065300.jpg
Impessive Motownbrowne.
Gordon, my logs are in the same size than your regular ones. I too have a few larger and many smaller but most are between 10 and 20 and inches soft wood.
And if I go with a winch, which of the Farmi 290 and 351 fits the best my L3800 ?
I had an opportunity for a used 351 but the guy decided to keep it, so I would go for a new one, so better buy the best fit. Any accessories to buy at the same time ?
Thanks again !!
   / KUBOTA L3800 log trailer sizing #20
Hi neighbour i have a Kioti CK35 and 3001 Igland winch and work pretty good. I have about the same size of tree on my wood lot . Igland winch is very simple to work with and easy to replace cable and pulling pads if needed. Do some little modification on it like a chain saw holder , trailer hitch, top pulley and if you buy a winch make sure you made you a self release pulley or buy one work very well and save you some precious time and step.... Now for your log loader and trailer am looking for one right now have a lot of guys around here who have that kind of set up for there sugar house and they love it..... do you check metavic and woody company in Quebec very nice log loader and trailer...:thumbsup::thumbsup:
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
Ez-Go Electric Cart (A55853)
Ez-Go Electric...
Red Cedar Wood Rocking Chair (A55853)
Red Cedar Wood...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2014 International Derrick Digger Truck (A55973)
2014 International...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
