Poor man's self propelled sprayer :)
/ Poor man's self propelled sprayer :) #3
You can't be too poor if you can afford that tractor! Bob
/ Poor man's self propelled sprayer :) #4
Nice set-up, will that go on the 3pt also? Looks like a top link connection in the close-up pic of it in the loader bucket.
Maybe a set of poor man backhoe stabilizer pads next. You must be sliding around with that big bucket.
It has a 3pt. mounting framework the tank sits on. The pastures I spray are long and narrow so it's easier to avoid the fence if I see it out front. The backhoe has stabilizer pads already. Unless I'm not getting your meaning right.
/ Poor man's self propelled sprayer :) #7
The flat plates on the end of the stabilizers are for mounting pads, thus the 6 holes. Have seen some good diy pads. Here's a Big Foot pad and a Kioti rubber pad
/ Poor man's self propelled sprayer :) #9
Now that I looked at it on a desktop machine I can see the part of the pad that digs into the ground. My mistake.
Mike, I like your thumb on the hoe. Is it mechanical? Do you find yourself getting off of the machine to often to adjust it?
Something on my wish list and I can't justify a hydraulic unit.
It's a mechanical thumb. When picking up poles or smaller logs with it I just set it where it will grab the log at at the right position on the diameter. Other than that I don't use it much. It came on the hoe and I wouldn't ever guy one unless it was hydraulic.
/ Poor man's self propelled sprayer :) #11
That baby is nice... and just think, those self propelled units are over 200k. But they do come with 120' booms.
/ Poor man's self propelled sprayer :) #12
Thanks Mike, seems to be the consensus. I'll have to move it down the list and save for a hydro one.
My pastures aren't 120' wide in spots. :) Another reason I don't need GPS product control on the sprayer. :) Nobody around here uses self propelled anyway. The ground is way too steep for them.
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A65563)
2016 Hino 195h...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
(4) Skid Steer Tires (A62613)
(4) Skid Steer...
