Poor man's self propelled sprayer :)
/ Poor man's self propelled sprayer :) #3
You can't be too poor if you can afford that tractor! Bob
/ Poor man's self propelled sprayer :) #4
Nice set-up, will that go on the 3pt also? Looks like a top link connection in the close-up pic of it in the loader bucket.
Maybe a set of poor man backhoe stabilizer pads next. You must be sliding around with that big bucket.
It has a 3pt. mounting framework the tank sits on. The pastures I spray are long and narrow so it's easier to avoid the fence if I see it out front. The backhoe has stabilizer pads already. Unless I'm not getting your meaning right.
/ Poor man's self propelled sprayer :) #7
The flat plates on the end of the stabilizers are for mounting pads, thus the 6 holes. Have seen some good diy pads. Here's a Big Foot pad and a Kioti rubber pad
/ Poor man's self propelled sprayer :) #9
Now that I looked at it on a desktop machine I can see the part of the pad that digs into the ground. My mistake.
Mike, I like your thumb on the hoe. Is it mechanical? Do you find yourself getting off of the machine to often to adjust it?
Something on my wish list and I can't justify a hydraulic unit.
It's a mechanical thumb. When picking up poles or smaller logs with it I just set it where it will grab the log at at the right position on the diameter. Other than that I don't use it much. It came on the hoe and I wouldn't ever guy one unless it was hydraulic.
/ Poor man's self propelled sprayer :) #11
That baby is nice... and just think, those self propelled units are over 200k. But they do come with 120' booms.
/ Poor man's self propelled sprayer :) #12
Thanks Mike, seems to be the consensus. I'll have to move it down the list and save for a hydro one.
My pastures aren't 120' wide in spots. :) Another reason I don't need GPS product control on the sprayer. :) Nobody around here uses self propelled anyway. The ground is way too steep for them.
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
Concrete Cut Off Saw (A66408)
Concrete Cut Off...
