Pleaae play it safe
/ Pleaae play it safe #3
Thanks for the reminder - sorry about the sadness in your friends life.
Not good at all . What happened ?
I am sorry you did not realize what happened...they are certain that the fire in the mobile home was caused by an undersized extension cord being used to power a space heater. I do think I made that clear.
/ Pleaae play it safe #5
Yeah, undersized extensions.
Friends tenant left for a short period and turned down all his heaters to low.
Well those portables were on dollar store extensions, probably up to 3 (like one in each hole).
Well it went really cold on Xmas nite and all those heaters tried to raise the temperature but stayed on so long in the attempt that a fire started causing $400k damage.
Quite simple to understand; 3000 watts on #16 (or possibly #18 wire) with a 30 amp fuse in the pannel = disaster.
Took friends insurers almost 1 1/5 yrs to settle as street rumors hinted on arson.
Fire started upstairs and burned a 10 ft hole thru the floor and you could see where the wires melted.
The structure stayed standing but with big burn holes in the roof and humongous water damage.
He re built (bigger and better) but had terrible time getting insured on new building.
/ Pleaae play it safe #6
I happen to live in the same county where this happened. Very sad. The daughter was also in a burn unit and had lost all of her fingers and one thumb but in the end she did not survive.
/ Pleaae play it safe #7
Yeah, undersized extensions. Friends tenant left for a short period and turned down all his heaters to low. Well those portables were on dollar store extensions, probably up to 3 (like one in each hole). Well it went really cold on Xmas nite and all those heaters tried to raise the temperature but stayed on so long in the attempt that a fire started causing $400k damage. Quite simple to understand; 3000 watts on #16 (or possibly #18 wire) with a 30 amp fuse in the pannel = disaster. Took friends insurers almost 1 1/5 yrs to settle as street rumors hinted on arson. Fire started upstairs and burned a 10 ft hole thru the floor and you could see where the wires melted. The structure stayed standing but with big burn holes in the roof and humongous water damage. He re built (bigger and better) but had terrible time getting insured on new building.
Who heats a house of that value with space heaters?
/ Pleaae play it safe #8
My heart goes out to those that have suffered.
But the generic "play it safe" admonishment falls on deaf ears (mine anyway) Yes, I try to do things safely. but as a realist, I know there are risks. Automobiles for instance. They are more the risk to us all than "house fires".
Falls in the home are number one! (IIRC). What can one do to climb or descend stairs "safely"? Use the hand rail?
Perhaps if this post were specific to the loss I would be more sympathetic. General supplications to "be safe" just don't do anything for me.
I do not keep bulk rolls of bubble wrap at my bedside for when I start the day.
I DO ride motorcycles, often at high speeds.
I use power tools, machine tools and powered equipment often, often without all "recommended" safety equipment.
I do take responsibility for my actions.
I do make every effort to not endanger anyone else while I go about living my life.
"Live simply, that others may simply live.!"
/ Pleaae play it safe #10
And never use gasoline to get a burn pile going...
/ Pleaae play it safe #11
I cut for firewood, burn my brush piles yearly. Work with another guy occasionally. He by gosh INSISTS that one needs to at leasst mix gas with the diesel. This in spite of me demonsstrating repeatedly that diesel sstarts just fine with one match and it is the diesel in his "mix" that does the work. Gas just goes WOOSH and dies, diesel keeps burning long enough to start the fire.
There are others in my breakfast group that insist on gasoline also.
/ Pleaae play it safe #12
I use gas and used motor oil at about 50/50. I have used more gas. The "whoosh" does give me an adrenaline rush- though I am smart enough to stay upwind of the fumes when I light it.
/ Pleaae play it safe #13
Sorry for the family's tragedy...
As to burn piles this may be a good time to repeat my no fail way of lighting brush piles. Leave an alcove underneath the pile that you can access. Get one of those chimney style charcoal starters that use crumpled paper under the charcoal. Have a support underneath the pile that the lit charcoal can sit on (I use an old shovel that is missing it's handle). After a few minutes when the charcoal is burning well in the starter chimney, pour it into the alcove and make sure enough material is directly over the burning coals.
I've used this method to get soaking wet piles started with ease while it was raining. The burning coals put off enough heat to dry out and engage the material above them and get a good core fire going, no muss, no fuss.
/ Pleaae play it safe #14
Good idea. I do similar, using a small fire starter log when the pile is damp/wet. You can get 20 of them for $10 at the local co-op. A lot safer and cleaner than fuel. When dry, I just use paper or old feed sacks.
/ Pleaae play it safe #15
I save old 5 gallon oil buckets with the lids and save used motor oil in them. Then I burn it in brush piles. I end up draining bad gas out of other people's equipment who wasn't smart enough to put ethanol free gas in it and that gets mixed with the oil but it's not necessary.
/ Pleaae play it safe #16
'nother thing that works great is to soak some tentest chunks with fuel and once ignited burns just fine.
My fireplace gets started using egg cartons, I get the big 12 x 12 (trays) from the local breakfast place. One 'tray' and 5-6 pieces of kindling and one match does it every time.
/ Pleaae play it safe #17
A trick I learned here on TBN is to soak a roll of toilet paper with diesel then put the roll as far in the pile as you can and light it. I have burned wet piles this way.
Norm
/ Pleaae play it safe #18
makes one wonder, if the wire got that hot, why it never tripped a breaker, or blew a fuse ?
1993 Ford Mustang GT Car, VIN # 1FACP42E0PF158263 (A65563)
1993 Ford Mustang...
Husqvarna MZ61 Zero Turn (ZTR) Mower (A66285)
Husqvarna MZ61...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Single Cedar Glider (A65583)
Single Cedar...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
