Shop light suggestions
/ Shop light suggestions #21
I bought 4' LED shop lights off Amazon...Absolutely love them--Put up with the T serries bulbs for too long...You wouldn't believe how bright these are...Lighting 30x48.
/ Shop light suggestions #22
Do they interfere with wireless signals?
/ Shop light suggestions #23
Whatever you decide to buy, make sure to look at the efficiency: Lumens/watt. If that number is less than 100, I wouldn't bother buying the light.
For simple shop lights, it's hard to beat the Sams Club/Honeywell 4' 2 pack shop lights for $60: Honeywell LED 4' Shop Lights (2-Pack Silver Finish) - Sam's Club
4500 lumens each for 42 watts of power consumed = 107 lumens/watt, not too shabby.
/ Shop light suggestions #24
i am favor of the old screw in light bulbs, placed any were from 2 to 4 feet apart, and having a line going down one side, and another line of lights going down the other side, and then in middle having 1 or 2 much bighter / costlier lights.
to many times more so in winter turning on lights and needing to wait for (bright costlier center ) lights to warm up before they put out full light. by that time i already found the tool i needed and locking the door behind me. and reason for the cheap screw in light bulbs around the outside edge.
to many times it is just plain "DARK" when i need to work at any side wall were a tool is located or looking through part bins and like, or i am casting a large shadow of myself exactly were i want to look and no way to get around it. and those cheap screw in light bulbs. around the outside edge. reduce and shadows due to coming in from multi angles, and generally if the cheap screw ins are 2 to 4 feet off side of bulding, they end up between me and what i am looking at, vs light bulb being behind me and casting a shadow.
the 1 or 2 much brighter / costlier light in the very center. = wanted simply due to they give out so much extra light vs the cheap screw in. allowing me to see little cracks / hair / pencil marks and like. that i might not see other wise.
i am not a fan of florescent lights (tube lights), while they can be nice if you have enough, they take some time to warm up, they can flicker, and they can hum / buzz all day long, and generally requires a ladder and a couple trips up and down it to deal with light cover, removing old bulb, and putting in a new bulb. most of my garage is filled with something making a pain to get a ladder in some place (normally were it needs to be replaced of course) the cheap screws quick and easy, and a few cheap tools on market that you can use to reach up and undo without need of a ladder.
i am just not a fan of the long bulbs, make it led, to florescent bulbs / lights. lots of light in a single spot. but not were you need/want it, when you need/want it. and most likely right in the way hanging down, right were i want to shove something up on a shelf or pull it off a shelf. or i end up nailing the light due to hanging lower with a ladder when moving it around or dealing with lumber.
the cheap screw in lights = 1 to 2 bucks for the plastic piece were light screws in, it also acts as a cover for a metal junction box which you can buy from 50 cents to 1.50 at menards. and light bulbs buy a 10pack for 10. approx 3 to 5 bucks per light. run a string of them down each side for of 40x60 shop = figure 10 to 30 lights per each side, 60 to 300 bucks not counting center lights. think of them as cheap track light / christmas tree string lights but much brighter!
an edited picture i did for someone else, showing some cheap lights, 3 rows (left, center, right) and then a light above the sliding door on the outside of the shed. *shrugs*
/ Shop light suggestions #26
How high are your ceilings? Is it open rafter or drywalled in? I will also sing high praise for the Costco 4ft LEDs with fixtures. Worst case they are $29.99, last year they dropped with price down twice w/instant rebate to $24.99 and $19.99 (just before Xmas). These are great on finished ceiling less than 10ft. White ceiling/walls help too. Love the bright white light will low consumption. My shop is power deficient so these really helped. I can't comment on high shop ceilings that may be darker to start but I would go LED regardless. It the reliability that is the tough question with these new high power LED light fixtures.
how high is your ceiling?
My wall height is 14' but my shop is Ibeam construction so the pitch of the roof puts the lights at roughly 18-20 ft mounted on c purlin.
/ Shop light suggestions #30
12' not finished..Very happy with the light..Look at them and get a trailing visual---Very bright. Not cheap but very happy with them. No light up delay in the 0 degree temps and no buzz.
Might be able to see a few of them on the attachment.
/ Shop light suggestions #31
Timswi - Those LEDS light up the space super well and makes the truck shine. Do you have these plugged into receptacles that are switchable?
/ Shop light suggestions #32
They are plugged into swtchable recepticals.
/ Shop light suggestions #33
I've got a small shop (2-car garage) and recently added a few of the 2@4' LED fixtures as well (Costco); I also got some of the tube LEDs that you can put into an old fluorescent fixture (they work just as well).
Personally I like the tubes because instead of there being a small incredibly bright sources of light (which will blind you from an errant glance), the light comes out of the long strip and so there's less intense glare and no shadows.
My advice: You can't have too much light; In my shop I now have 8 of these fixtures for the ~24x24 space and it's literally as bright as day inside (honestly a bit much to come into at night at first, but there's no worry about eyes tiring due to insufficient light any more). Install them on multiple circuits, either by zone and/or interspersed so you can turn off every other one if you don't want as much light (n.b.: most of these are non-dimmable) but honestly I haven't thought to myself "it's too bright". The LED lighting is high quality and I don't get any notion of flicker at all (I'm terribly sensitive to that and most fluorescent makes me nauseous after a while).
To fully light a 30x60, I'm guessing on the order of 20 of the 2@4' fixtures.
/ Shop light suggestions #34
ning,
Your experience is the same as mine. There is no way i'm going to line the ceiling with a bunch on incandescent bulbs that waste 90% of the energy as heat. And I am so done with fluorescents too. Buzzing, strobing, slow warm up, etc. But for those with conventional light fixtures, the LED screw in bulbs are about the same price as incandescents.
Tube LEDs are very nice.
How do you install the LED tubes in the old fluorescent fixtures? Do you have to re-wire them to get away from the starting capacitor and transformer? Is it reasonable to do that when a whole new LED fixture with bulbs and cord is only $30.? And do the electrical connections on the LEDs match the ones on the Fluorescents?
When I go out to the garage/shop at night to get something, I turn on a smaller light with a switch near the door. I actually have five lighting circuits in there, so it's easy to just get enough light to get something without blasting myself. I also have some night lights in there too. They draw next to nothing but make a small glow throughout the area and then come on brighter during power failures.
/ Shop light suggestions #35
I have six of the Costco 4ft LEDs installed in my two car garage. I decided just to replace the fixture and all and gave the old fixtures bulbs away to my son for his garage. I bought four more for me addition coming hopefully this summer. I have two fixtures on one switch and the other four on another switch. Gives some options. Probably put the rest on another switch for the addition. They mate up nicely with the ceiling. Not quite flush but no more chains and hanging fixtures.
/ Shop light suggestions #36
There are 4' LED tubes which go right into a ballasted fixture with no mods, and others which require you to disconnect the ballast - I believe the latter is the better way to go if you're not replacing the entire fixture. I bought a pack of the "simply replace the tube" types to see how well they work with an old tired ballast (works great even in the cold) and also bought some new 4' LED fixtures as my shop had insufficient lighting. I haven't bought any disconnect-the-ballast type; they're probably slightly less work to install than replacing the entire fixture so price-for-price I'd probably go that route when replacing otherwise unless I disliked my current fixtures.
For what it's worth (and off the shop-light topic), I've replaced lots of BR30 and BR40 can light bulbs with LEDs. Quite happy - they've got a good color and tons of light; I never had good luck with CFLs (they died on me faster than incandescents and had lousy light).
ning,
/ Shop light suggestions #37
My shop is 50x50 and I have 20 regular screw in fixtures on the ceiling. When I built it 7 years ago I put 85 watt (actual - not equivalent) in them that are about 10" long. They have worked well but have recently started making noise and seem to take longer to warm up. I plan to replace them with LEDs but am still searching for the right ones.
I am a big fan of installing the screw in sockets because it is super easy to replace bulbs as needed and as technology evolves. Those costco 4' leds are slick but in five years I bet there is something much better and with the screw in sockets your upgrade path is limitless.
/ Shop light suggestions #38
85 watt what....? CFL, LED ETC
/ Shop light suggestions #39
Sorry - CFL. They are huge though and I have been pleased with them but there are better LED options now. They were about $20 a pop when I got them. Not a single one has failed in 7 years but like I said there are some that just recently started making a buzzing noise and they seem to take longer to warm up and get bright than they did when they were new.
/ Shop light suggestions #40
I installed x2 of the RuggedGrade LED lights I bought off Amazon. I plan on installing two more.
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
CASE TV450B SKID STEER (A64279)
CASE TV450B SKID...
