Most powerful ZTR mower?
/ Most powerful ZTR mower? #1
MultiMow
Gold Member
Wytheville, VA
Toro 325-D 4WD
I've been comparing ZTR power units, and thought I'd see if anyone knew of any higher horsepower units than what I've found.... new, or old.
So far...
Highest horsepower diesel:
Yazoo Kees - 38hp Kubota (turbo)
Highest horesepower diesel (non-turbo):
Multiple mfg - 35hp Caterpillar/Perkins
Both the above are pre-Tier 4 Final engines.
Current (Tier 4 Final):
John Deere 997 Diesel - 37+hp (Perkins or Yanmar?)
Noteworthy:
KutKwick Brushmaster and Mega SlopeMaster - 83hp Yanmar
KutKwick Super SlopeMaster - 38hp Yanmar
Gasoline engines:
Kohler and Kawasaki both have 37hp V-twins in several mfg models.
What have I missed?
It would be cool if we could keep this thread going with various other superlatives, such as deck width, most powerful with independent transaxle, etc.
Right now, the most powerful single axle model I've found, is Kubota's one ton monster 1500 series diesel, with 31+hp.
/ Most powerful ZTR mower? #2
Why do you need the highest hp mower in existence? The Kubota shaft driven double V belts are the setup I've found that can actually use all available power. Most of the other ZTRs use a single V belt to drive the deck which can't hold the available power of a usually 25 hp motor.
/ Most powerful ZTR mower? #3
Can't say I agree.
I have a 35 HP (Kawasaki engine, Hustler Super Z, 72" deck) on my zero turn with the single V belt deck.
I can mow at speeds until the engine is straining for power and never slip the belt from my experience.
Never noticed any belt slippage. Never.
The thing will mow my 8 acre yard in 2 hours.
It's not a need... more of a curiosity.
I agree on the Kubota power transmission. The 331 and new 1500 series successors have the most efficient powertrains on the market, when it comes to sheer transfer efficiency. Their integrated single axle is fine piece of engineering. The only trade-off is weight.
Looking into the proverbial "crystal ball", I'd say Kubota has far more plans for that architecture than just zero turn mowers... which is what sparked my interest altogether.
I just thought it was an interesting topic for comparison... and apparently, so do the manufacturers, considering that it's pretty tied for 1st place with cutting width, in terms of priority specs, sales, and marketing.
/ Most powerful ZTR mower? #5
My Ferris has a humble 26hp gas engine. it also has an air seat and full suspension. It's like riding around a comfortable ATV that mows. Top speed is 12 mph.
/ Most powerful ZTR mower? #6
I don't think the new Vanguard 37hp EFI engine has been mentioned. That one would be my choice if I was picking a gasoline engine in a mower and needed all the power I could get.
You're right, I forgot that one.
The new version with dry sump lubrication and 500hr service interval is a sweet unit. All lube service points are remote mounted, too... so no more fighting with drain plug locations and oil spilling into places it shouldn't be (belts, etc.).
Thanks Paps!
2024 John Deere 6130M Tractor Loader (A63109)
2024 John Deere...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2005 Ford Explorer SUV (A61569)
2005 Ford Explorer...
