Electric trailer brakes
/ Electric trailer brakes #1
Michael Aos
Gold Member
Colorado Springs
Kubota BX2370-1 RTV500
I have a 2003 Tundra Access Cab. TRD Off-road 4x4, 4.7L.
Just purchased a Load Trail 5x10 dump trailer. Capacity is roughly 2-tons / 2yds.
It has battery-operated hydraulics, and battery-operated emergency breakaway brakes.
My question is whether I need some kind of special electric brake controller to utilize the electric trailer brakes, or do they just work "automagically" -- or is there even an option to utilize the electric brakes in everyday circumstances, or are they emergency / breakaway brakes only?
/ Electric trailer brakes #2
If your tow vehicle has a trailer brake controller, it will apply the trailer brakes when the tow vehicle brakes are applied. Most new trucks have them from the factory, your 03 is likely to not have one. Google and YouTube can easily guide you through the install. Please take the steps needed to get them operating properly.
I have no issue taking it in and having a brake controller installed.
I just don't want to bring it in for a brake controller installation -- which they'd be more than happy to perform -- if I don't need it or can't take advantage of it.
/ Electric trailer brakes #4
I'd imagine it has electric brakes for stopping AND emergency break away.
Yes, you'd need a brake controller to utilize the brakes for stopping. There are many brands. Some trucks come with built in brake controllers as well.
You install the brake controller in the cab, wire it in and it will feed the brakes through the trailer wiring harness.
If you've never used a trailer with brakes and a braked controller, you should really find someone that has so they can show you how to use them.
If you don't have anyone, U-Haul is sometimes a good place to start. They install hitches, brake controllers, etc...
Your break away system uses the same brakes that you use for stopping. It just has a tether that attaches to the tow vehicle. If the trailer breaks away from the hitch, the tether will pull out a switch on the trailer as it falls behind, and that will activate the battery operated circuit to apply the trailer brakes regardless of if the wiring harness to the tow vehicle is connected or not.
/ Electric trailer brakes #5
Yes!
You DO need a brake controller.
You can have it installed at any RV place, or hitch install facility.
Do NOT use your new trailer (loaded) unless, and until, you have a controller installed.
Then,... READ the instructions carefully, and be SURE that you understand how the system works.
The amount of braking desired is adjustable, and how to set it will be described in the brake controller instructions.
/ Electric trailer brakes #6
/ Electric trailer brakes #7
You'll need an electronic brake controller. Not 100% sure, but I believe that year is pre-wired for it, so you just need the controller. The wiring harness should be in the dash, in mine it was on the left side of the driver side footwell, some other years it is on the right side, your manual may tell you. When you mount it make sure you put it in a place where you won't smack it all the time... Got in an accident and broke 2 fingers on mine!
/ Electric trailer brakes #8
/ Electric trailer brakes #9
Absolutely yes, you need a brake controller.
Sounds like you need to visit your trailer dealer or a local trailer hitch shop and have one installed.
Your selling dealer should have never let you leave the lot like that!
/ Electric trailer brakes #10
I have a 2007. It didn't come with built in controller, I had to purchase a controller. I bought a pig tail from toyota dealer . plugged it in under the dash and wired the controller to pig tail. the rest of the truck from front to rear was pre wired. Don't know about a 2003 model
/ Electric trailer brakes #11
When you go get the electric controller keep a couple things in mind.
1. Get one with a digital readout so you can know what you have it set at for feature use in different conditions or loads. Loaded and unloaded will need different settings usually.
2. Make sure the read out can be read in BRIGHT light so you can easily read it going down the road. Blue light seems to work better than red read outs for me.
3. Get one that is adjustable for how hard it sets the trailor breaks and for how quick it activates when you apply the trucks breaks.
4. Now for the one thing that many installers do not do. Have the brake controller installed where you can easily see it, adjust it, but for darn sure where you can easily reach it WITHOUT looking at it so you can manually activate the trailor breaks. This is incredibly useful if / when the trailor starts to fishtail a bit from ice, water, debris on the road or poor loading. You can reach down and WITHOUT LOOKING gently apply the trailor breaks and not hit the vehicle breaks. This allows the trailor to straighten up and get things back under control often times. This also allows you to pay attention where your driving and going instead of looking down at the dash. Bridges icing over in winter time are a prime example of a issue that one would not think you would encounter. And that dump trailor will be easy to load incorrectly with the resulting problems to deal with. Practice with it a bit and its not a bad idea to tap it once after you first hook on to make sure the breaks are working.
/ Electric trailer brakes #12
I'm happy with my Teknosha Prodigy 3. My 2009 Tacoma had a pigtail in the glove box. 1 end plugged in under the dash, you had to solder or crimp the other to the pigtail on the controller. Easy install, but I'd find a pro to do the install if you aren't familiar with electrical stuff or brakes.
My F250 beater came with some cheap no name time delay type controller. I hate it, no matter how you adjust it the trailer brakes hit to hard a second into braking, or occasionally not enough. Do yourself a favor & get a good momentum sensing unit.
As others said a digital display is handy, but not required. I rarely look at my display now & adjust by feel. The display makes for food staeting spots though. Every time you hitch up or load/unload you should adjust your controller. Get up to 30 or so on clear road & hit the manual lever. The trailer brakes should aggressively slow you down. Keep upping the voltage/gain until you lock up the brakes, then back it off so they don't lock up. Will take you 5-10 minutes the first time, then 30 seconds maybe a minute after a few times when you get a feel for it.
It should be easily reachable for adjustment & oh **** situations. If you hit the brakes when fishtailing it's game over. But if you manually engage just the trailer brakes with the lever on the controller it will straighten things out & save your life.
See if you have a buddy you can pester for 10 minutes to have him explain his controller.
/ Electric trailer brakes #13
The last prodigy I installed I bought with a pre-made harness for the truck, well worth the small expense.
/ Electric trailer brakes #14
I'll +1 the Tekonsha Prodigy line and the advice to mount where reachable without looking. The Prodigy has the nice feature of additional "profiles" affecting how the controller applies the current setting which you can select by a single button press to increment through the list. Each "bump" increases the aggressiveness of the brake application timeline, while keeping within the base settings min/max values. Example, you might use the base setting for empty, +1 for a light load +3 for a heavy load, etc.
Be sure to read the manual regarding the trailer brakes. Some need manual adjustment after they wear in over about 200 miles, some will automatically adjust when rolled in reverse - see which is true of your trailer. The initial setting of the brake controller also requires a bit of driving & experimentation to find the point where the setting is as high as possible without resulting in trailer brakes locking up significantly before the tow vehicle brakes. This is best done after a bit of slow driving & light brake application to do an initial "wear-in" of the trailer brakes (the manual will describe it best).
Nick
/ Electric trailer brakes #15
Ditto on the Tekonsha P3 Prodigy. Excellent controller, easy to change trailer settings if you own multiple trailers of different sizes and weights.
/ Electric trailer brakes #17
Tekonsha fan here, too. Slightly off topic, but interesting to me is that when installing a brake controller on new vehicles with advanced safety systems like automatic braking, Tekonsha recommends installing a 1 amp diode in the tap off the tow vehicle's brake switch. The diode prevents back feeding into the vehicle's system. One down side to this is that when you manually apply the trailer brakes using the controller, it will not light the trailer brake lights. With no diode, the tow vehicle (a 2017 Highlander in this particular case) will throw codes and the cruise control will not operate.
/ Electric trailer brakes #18
I picked up up a F250 to P3 cable & a new mounting bracket for my P3. Really wanted to replace that crap time delay controler that came with my beater F250. Unfortunately I found they chopped off the stock plug to wire the crap controller. Need to get around to getting a new stock plug of a wrecked truck or something & re attach it so I can use my P3 on the F250 as well as the Tacoma.
/ Electric trailer brakes #19
I'll never understand why people hack electrical systems, I guess it's to save a few bucks?
I just pulled the radio on my BIL 05 f150 because the only speaker that worked was the sub, he bought it used and I guess at some point, someone installed an aftermarket radio. Instead of installing an adaptor harness they cut all the wires to the main plug and put them back with crimp on spade connectors, my favorite part was where they left a cut wire that had been tapped onto another wire after removing the insulation and then held on with electrical tape.
The truck is a higher end model also so why you wouldn't spend the couple bucks to buy an adaptor is beyond me, instead they hacked the harness up.
/ Electric trailer brakes #20
Well, that is certainly a bummer! We WERE looking at the new (2017) Highlander, but I think we'll pass now.
Landhonor 2-Ton Hand Chain Lever Hoist (A66408)
Landhonor 2-Ton...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New/Unused Spirit Electric Bicycle (A65583)
New/Unused Spirit...
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
