Farm track 555 leak
/ Farm track 555 leak #1
jack707
up North wisconsin
farm trac 555
I noticed a few days ago I had a leak where the oil pan is first day was hyd. Oil next day I noticed it had anti freeze in it. What do you think it is? It's to far away to be the radiator but then again I'm no expert.
/ Farm track 555 leak #3
Not very clear what you are trying to say. Sorry. Can you post a pic of said leak?
/ Farm track 555 leak #5
I take it you haven't got the tractor real hot because its winter. Probably radiator leaking but could be a hose clamp loose or even the water pump weep hole. I would dry it up and try to find the closest place it's coming from. Good luck.
/ Farm track 555 leak #6
Guessing that is the front of the pan so yes I would guess Radiator leak or hose\ WP leak as said above.
/ Farm track 555 leak #7
You can actually see where it is running down the pivot. I have had 1 Radiator replace under warranty And just had a shop repair a leak that pretty much leaked right there. The overflow tube is also on that side too. If running hot or overfilled the engine gets a bit hotter after shut down and puke a little.
That's how it goes I don't see any anti freeze anymore now just HYD.fulid.
/ Farm track 555 leak #9
I would guess maybe power steering how is that for level
/ Farm track 555 leak #11
Sometimes they will only leak coolant when hot, after it cools hairline cracks will close up
Well thank alot! I found the leak. The two lines next to the box was a little wet but I don't notice anything when I drove it a few days ago.
Westendorf Loader Bucket (A66408)
Westendorf Loader...
(10) Massey Ferguson Tractor Weights (A65640)
(10) Massey...
NEW Wolverine 78" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 78"...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
