Farm track 555 leak
/ Farm track 555 leak #1
jack707
up North wisconsin
farm trac 555
I noticed a few days ago I had a leak where the oil pan is first day was hyd. Oil next day I noticed it had anti freeze in it. What do you think it is? It's to far away to be the radiator but then again I'm no expert.
/ Farm track 555 leak #3
Not very clear what you are trying to say. Sorry. Can you post a pic of said leak?
/ Farm track 555 leak #5
I take it you haven't got the tractor real hot because its winter. Probably radiator leaking but could be a hose clamp loose or even the water pump weep hole. I would dry it up and try to find the closest place it's coming from. Good luck.
/ Farm track 555 leak #6
Guessing that is the front of the pan so yes I would guess Radiator leak or hose\ WP leak as said above.
/ Farm track 555 leak #7
You can actually see where it is running down the pivot. I have had 1 Radiator replace under warranty And just had a shop repair a leak that pretty much leaked right there. The overflow tube is also on that side too. If running hot or overfilled the engine gets a bit hotter after shut down and puke a little.
That's how it goes I don't see any anti freeze anymore now just HYD.fulid.
/ Farm track 555 leak #9
I would guess maybe power steering how is that for level
/ Farm track 555 leak #11
Sometimes they will only leak coolant when hot, after it cools hairline cracks will close up
Well thank alot! I found the leak. The two lines next to the box was a little wet but I don't notice anything when I drove it a few days ago.
2016 JLG T350 (A64126)
Bobcat T650 (A64126)
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
John Deere 6000-Series Tractor Loader Frames (A65640)
John Deere...
Well Tank (A64127)
Well Tank (A64127)
2020 John Deere R4023 (A64126)
2020 John Deere...
