Overall width of Grand L 6060 with R-4 tires
/ Overall width of Grand L 6060 with R-4 tires #11
The R4s on Grands are adjustable. At least 4 different positions. R4s on the economy 00 & 01 machines are fixed & not adjustable. Pretty sure all R1s are adjustable.
I'm trying to figure out is that 67.3 to the inside of the tread for an r-4 tire or outside of the of the r-4.
If it's the inside of the r-4 then what would be the minimum and a maximum width to the outside of the tread for the standard industrial tires that would come on my L 6060 that I have ordered.
I'm trying to figure this out for some implements I'm ordering for example the Kabota rear snowblower I believe is 74".
If my tractor measures 74 to 76 inches with my stock industrial tires from the factory I may want to upsize my implements to the next size wider so I'm cutting a slightly wider tracked in my tires.
I'm trying to order these implements at the same time as the tractor and another example is I'm ordering a heavy duty box blade and they come in 72 inches wide and I think 80 inches wide. If my tractors a few inches under 72 then maybe I would go with the 72 inch box blade but obviously if my tractors 74 inches wide then I probably want to go up to the 80 inch box blade.
Unfortunately where I am in Idaho my dealer sells mainly all agriculture equipment and I don't believe they've ever ordered a Grand L 6060 and they certainly don't have any in stock for me to measure.
Even that there over an hour away from me so I have no close Kabota dealers to me.
Thank you
/ Overall width of Grand L 6060 with R-4 tires #13
Has nothing to do. with the tire other than how wide it is. The 67.3 is the minimum "tread" (e.g. center of tire determined by the steel of the tractor) plus the width of the tire = whole width outer edge to outer edge. Maybe easier to visualize as half the width of the tire added on each side outside the center. The spec sheet says your min center of tire width is 52.2 and max is 56.3. Fallon says (above) that the Grands have more adjustments than just the two choices of 52.2 and 56.3. Following up on that, you DO have 47.2, 51.2, 54.5 and 58.3 inches for 4 choices on the Grand rather than just 52.2 and 56.3. Add Your tire width to each of those numbers and you have your choices of overall tractor width from outside to outside of the rear tires. For heaven's sake with the cash you are putting out, the dealer better clarify that quickly and easily with a phone call if this is not clear. With a big smile.
Note that the specs on the Grand give you choices 2 inches wider and 3 inches narrower (overall width) that the cheaper machines offer.
Ok, I think i've got it.
So with the measurements you gave me above all I need to do is find out what the overall width of the rear industrial tires that comes standard on the L 6060 and that will give me my overall for available widths I could go with.
Thank very much. 😀😀😀
/ Overall width of Grand L 6060 with R-4 tires #15
Thank very much. ������
Right. Good luck & let us know how it works out with your new machine !
/ Overall width of Grand L 6060 with R-4 tires #16
Not certain if anyone stated the tire width so far in the previous posts... Apologize if this was already covered.
R4's tire width per Titan catalog:
10-16.5NHS: 10.9"
17.5L-24: 17.1"
R3 Turf:
29x12.5-15: 12.6"
44x18-20: 18.6"
So the rear r-4 is 17.1"
Thanks everyone very much. 👍👍😀
/ Overall width of Grand L 6060 with R-4 tires #18
If there is anyone on here with the Kabota grand L 6060 with the industrial tires?
Could you please measure what the overall width of your tractor is from outside of tires two outside of tires.
The Kabota website says 67.3 minimum but it doesn't mention if that's industrial tires or ag tires
Thank You
Though I've not measured mine lately, and cannot remember, I researched this before buying my L6060 in order to determine if it would work well with my Woods BB720X cutter.
The L6060 with R4s is a bit more narrow than my 72" cutter but it's close. I have the tires set in as far as is possible with R4s.
I just measured mine. It's just under 71" overall. There is about 2 1/4" clearance between the inside of the tires and the fenders. Didn't check to see if the tires can be set in any more narrow but wouldn't do so anyway because doing so would restrict tire chain clearance.
SDT
That's very helpful because as I said, I want to set it up so the outside of my industrial tires are at least 3 inches narrower than the 74 inch Kabota snowblower.
And I'm not sure if 74 inch on the rear Kabota snowblower is to the absolute outside of steel to outside of steel or the 74 inch is like the auger width.
I just wanted to make sure that after I cut a path with the snowblower that I had at least three or 4 inches on each side for the tires and a bit of maneuverability.
I really appreciate you taking the time to measure that for me.
Thank You
/ Overall width of Grand L 6060 with R-4 tires #20
This stuff is not all that precise of course, even though tenths of inches are quoted. I notice that your 6060 Grand has one choice of 54.5 and that plus the 17.1 inch tires makes 71.6 inches outer edge to outer edge. The 74" blower running behind that will clear theoretically 2.4 inches more than your tire path width. Two inches "ain't much" when there is snow all over the place and you may well want more clearance by going to the 51.2 spacing on the 6060 which adds 3.3 inches, a little over an 1.6" on each side or leaving the tire path a total of 5.7 narrower than the nominal width of the blower. It becomes a personal preference thing at that point as to what you want and whether you really care about small differences. I recommend you have the dealer deliver the tractor with the tires set to whatever width you decide on, agree on liquid in them or not, cast metal wheel centers for weight, if you chose that option, etc. He really should set this up the way you want it. Moving rear tires around yourself is not that much fun. Of course I do not know your operation, how much help you have, etc. I would be very surprised if the dealer in your area lacks quite a bit of experience with snow blower applications and he should be able to provide the direct experience/advice. I have no idea whether you have any steep slopes or significantly uneven ground on which this machine will be used. I am always more comfortable the wider the rear tires are apart. By the way, I like the inner edges of my front tires and inner edges of my rear ones to match in spacing.
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
Bobcat S740 (A57148)
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
USC Series 2000 Conveyor (A61307)
USC Series 2000...
