Adding FEL to Bolens 1502
   / Adding FEL to Bolens 1502 #11
Wondering what happens to the pressure if a branch on-does one of your couplers?
   / Adding FEL to Bolens 1502 #12
I have a TX 1500F. Looks like the same tractor as yours. I have a Brantly front end loader on my tractor and it has its own hydraulic pump driven directly off the front crank shaft. Works very well. Good speed and power to lift 900 pounds.
   / Adding FEL to Bolens 1502 #13
Sorry for digging up an old thread but wanted to post pictures of the FEL I am building for my 1502
I cut a much bigger Ford 770 loader down.
just starting the hydraulic lines now but hopefully it will be done in next couple weeks.
   / Adding FEL to Bolens 1502 #14
I look forward to your progress...
   / Adding FEL to Bolens 1502 #15
Started installing the hydraulics. Installed the hydro block and new quick disconnect hoses up to the
control valve. Next up have to modify the hard lines.
   / Adding FEL to Bolens 1502 #16
Hard lines cut down and secured with weld nuts
Now got to measure for the rest of the hoses.
   / Adding FEL to Bolens 1502 #17
Sorry for the ugly mug shot of the rider. Got my loader all finished up today and just playing around here.
Have 1 small leak at the trans cooler hose(not even loader install related) and need to swap 2 hoses around at control box because bucket goes up when it should go down and vice versa.
   / Adding FEL to Bolens 1502 #18
Looks gooder-un. :thumbsup:
Now you can build a brush fork for it. :D
   / Adding FEL to Bolens 1502 #19
Do you have any pictures of it?
How is it attached to the crankshaft. I removed my front PTO will I need the sleeve/spring and pin to use a front pump?
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2022 Horizon (A55973)
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
