Adding FEL to Bolens 1502
   / Adding FEL to Bolens 1502 #1
Cjr02
Texas
Bolens 1502H / Iseki TX2140
Hi all, new member with a new to me Bolens/ Iseki H1502. I'm doing a refurbish before adding a FEL for some light dirt work. I already have the loader.
I'd like to add connections for the loader while I have all the fluid drained. I was thinking of putting a quick disconnect set on the joint about 12" behind the pump, which I assume is there for splitting the tractor. I would have to use a short link hose when the loader isn't mounted. I like the idea of not cutting the hard line.
Is there a problem doing this? Im new to tractor hydraulics, is there a better way to go? Would I then use the PB port on the loader valve to go out to the 3 point?
   / Adding FEL to Bolens 1502 #2
I think I read somewhere on this forum that the small pump
on this type of tractor is inadequate to operate a front end loader.
Thanks for the heads up. There are actually a lot of these tractors with loaders. Bolens even had a factory option loader, the model 1517. I have a small loader, just looking to see if my plan for tapping hydraulics is sound. I'll put up a pic of the joint I'm referring to.
   / Adding FEL to Bolens 1502 #4
Your pump will be fine. I have a G194 w/a 60" plow. Factory set up. Have a Kubota loader I'm adapting. Will just take plow off and mount loader. My pump flows 3.1 gpm @2000psi. Your pump flows 3.0 gpm@1850psi.
Rich
Thanks, good to hear. I'm going ahead using this joint. Got some adapters to go from the metric compression fittings to npt. I found a pic of another tractor doing essentially the same thing. I'm going to run 2 elbows to point both fittings back, tucked in beside the side grille.
It worked pretty well. A couple elbows routed it so the coupler is accessible even with the side grille installed.
Incidentally, if anyone needs a replacement grille for a 1502, g152, g154, etc... a radiator grille from a 1999 arctic cat 400 ATV works well. Just had to bend the bottom out a little to clear the cooler lines. $12 on ebay.
   / Adding FEL to Bolens 1502 #9
You've inspired me to start my original plan to build a FEL on my TX2160F. Are you able to post a few more pics of your hydraulics set with the loader attached? I like your idea of tapping into the existing line. Have you also tapped into the return line the same way?
Thanks for your original posts, pics and ideas.
   / Adding FEL to Bolens 1502 #10
X2
Finally found someone with a 1517 loader who was close enough to me to make mounting bracket templates for all the bracing to mount/build my own.
Took lots of pictures and measurements for clarity as well.
Boy did he have a lot of parts and accessories for these tractors. Got a new source for parts now.
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
Mahindra 2516 Compact Tractor w/Loader (RUNS) (A50774)
Mahindra 2516...
