What did you do at work today?
   / What did you do at work today? #113
What is the end result of this fire pit going to be, is it something to cook hotdogs on? probably the only project here made with titanium.
That is what is so cool about this project... :cool:
I've engineered titanium in structural applications in my day job but haven't actually worked with it so I'm quite curious on hearing Kyle's perspective.
   / What did you do at work today? #114
I just want to see how it works with fire in it. How it radiates. How it holds up. I'm using some left over stock from a project that was finished about 5 or 6 years ago.
   / What did you do at work today? #115
I stumbled across your old cookie sheet thread about bending. Didn't realize I actually replied to that thread. How are the cookies and sheet still doing?
   / What did you do at work today? #116
Truth be known, my wife does not like it because it holds it's heat too long after removing from the oven. Other truths, I made a simple cookie sheet in 7th or 8th grade out of aluminum for my mom and she still loves them. I know, cooking on aluminum is probably bad, and I ate plenty of cookies off of those sheets. That's why I'm now crazy enough to make a Ti firepit. LOL.
Besides copper, of the cheaper metals, aluminum is best at thermal transfer.
   / What did you do at work today? #117
I made a skirted spool for a spinning reel out of a Ti alloy. (Ti-6Al-4V) Got a little careless with speeds and feeds and the birds nest of chips caught on fire and burned violently. It burns like magnesium. White hot and quickly.
Former employer had to change the way they dry blasted their medical implants cause the ti particles would settle out in the exhaust duct and catch on fire.
   / What did you do at work today? #118
yes, fine threads or shavings can catch fire. Old Kodak flash cubes had titanium filament in them. Usually, plate Ti does not catch fire. I will be sure to place it away from any building.
   / What did you do at work today? #119
Nothing much actually.. Just lazing around..A very unproductive day I guess..
   / What did you do at work today? #120
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
2012 Travis Body & Trailer Trailer, VIN # 48X9R5323C1007837 (A54865)
2012 Travis Body &...
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A52706)
UNUSED RAYTREE...
