What did you do at work today?
   / What did you do at work today? #101
Interesting project! Share more and/or start a thread on this if you can!
I'm actually not sure how it will turn out. I don't know how much it might warp if I get it too hot. The plates are 1/8" thick pure grade 2 Ti. It welds like butter. I just wanted to try it and be different.
I looked for titanium fire pits prior to making this. The main thing that comes up is a lightweight, small folding device, designed for a backpack hiker.
I know they use titanium for the SR 71 skin, to take the heat, but probably the Ti6Al4v alloy.
I designed it up in Cad, from something I saw and now I can't seem to find it. Original design I had incorporated a slit at the bottom of the V for drainage and breathing (hotter fire), but I decided that since it is so light, I can just tump it over to drain and clean it. I will add some holes to the legs, that will be rather simple, to mount a bushing and a pole for a grate.
By the time I finish it, our cool weather will be gone.
One thing I learned about titanium grade 2, you need either carbide tipped sawblade, or a crate of replacements. I ended up cutting the end triangles on the mill with coolant and a 1/8" endmill. Light depth of cuts, no big hurry.
   / What did you do at work today? #102
What are you welding with?
   / What did you do at work today? #103
Miller Synchrowave 250 with the water cooled torch and foot control. It was the first time in 9 years that I actually ran it hard enough for it's cooling temp fan to kick into high.
I ran the Argon a bit on high side. I did not purge the backside. I actually wanted the purple lines from welding as a decorative thing.
   / What did you do at work today? #104
I didn't think titanium will withstand much heat before melting, thought maybe little more than aluminum.
   / What did you do at work today? #105
The specs say it liquefies at 3030F. I don't actually know how it will hold up to fire pit usage.
   / What did you do at work today? #106
Nope... service temperature of Titanium is about 3 times higher than Aluminum!
   / What did you do at work today? #107
I am still doing my work thing. We, the whole refinery are getting ready to start back up. Had some crude issues beyond our control. This picture is my control board. The PC is currently on the TBN site doing this posting.:laughing:View attachment 499074
Man, when does the rocket take off?
   / What did you do at work today? #109
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
1472 (A51247)
1472 (A51247)
