PHD Storage?
/ PHD Storage? #1
40_acre_mule
South Mississippi
Kubota L4701
Hey y'all,
How do you store your post hole digger?
Without something else to support it, it is a pain to attach/unattach by myself. Also, I don't want to just leave it laying on the ground.
Did you build a rack to set it on or maybe some kind of hanging rig?
Thanks in advance for any ideas.
Mule
/ PHD Storage? #3
Currently my PHD is sitting on 4 boards. I did cut a large chain link in half and welded it toward the top of the boom pole and can support the PHD from a tree branch with a chain or rope but don't have a tree branch handy where the PHD would be out of the way for snow plowing.
/ PHD Storage? #4
If you have a smooth floor, a dollie is hard to beat. With casters you can get things lined up pretty easy.
Nick
/ PHD Storage? #5
Saw this on YouTube. Seems simple enough. I just park mine in a partially dug hole.
/ PHD Storage? #6
Mine is tied to a tree with a chain. Hangidown parts are kept off the ground with pavers I had laying around.
/ PHD Storage? #7
Couple of posts that I salvaged from a remodel job and a chain wrapped around the top make it real easy to attach and remove my post hole digger.
/ PHD Storage? #8
Nick
Nice job Nick - looks very similar to mine. I added bigger casters this winter so it works on gravel. TSC has a great selection. To the OP this is a good way to go. If you search this topic, there are probably hundreds of options. Nicks stand is simple and easy to use.
/ PHD Storage? #10
Mine have been 2x6 secured with decking screws.
Nick
/ PHD Storage? #11
Old pallet, couple 2x4s
/ PHD Storage? #13
Tying the auger bit up near the gearbox and again about a third the up from the bottom to a utility pole, fence post, or a tree works pretty good too but it doesn't keep the shaft end or the pins off the ground unless you place them on a block of some sort.
/ PHD Storage? #14
Mine hangs from the rafter on the lean-to on the side of my barn. It's hooked to a come-along, so I use that to move it up or down to align it. Works pretty well, I put it on the tractor last week and it only took maybe 10 minutes to get it hooked up, probably less.
iDrive TDS-2010H...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2006 Hudson Brothers Trailer HTD18D Trailer (A62613)
2006 Hudson...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
John Deere 4520 (A60462)
John Deere 4520...
