Pull type Grader?
/ Pull type Grader? #1
CDN Farm Boy
Ottawa Ontario
Kubota B3300SU
I'm considering building a pull type grader and looking for opinions.
My lane is about 1200 ft of gravel and my current choices to maintain it are a 7' rear blade, 5' box blade or a 3' wide really heavy LPGS. My wife likes the grass strip in the middle which is why I built the LPGS but have found that the RB when angled about 60 deg works better at getting out the pot holes. I grew up on a farm with a 1/4 mile lane and all we ever had was a rear blade. Plenty of experience behind the wheel. I need to add at least 6" of gravel this summer, 12" would be better if I can afford it so the grass strip will have to re-grow.
My only choice of delivery is a live bottom tri-axle truck which will leave the gravel in a 3' wide strip down the middle for me to spread. Trees down both sides prevent traditional tail-gate spread from a dump truck and the turn is too tight off the road for a belly dump. It's pretty clear to me that the only reasonable option is to use the angled rear blade to move the gravel sideways. I'd like more control on the consistency of the height than the standard RB allows. Plenty of skill to build whatever I want but budget is always a factor (I'm cheap and my wife is cheaper)
I can see 3 options:
#1 Add gauge wheels to the back of the RB. This is clearly the cheapest but the least versatile and probably not as effective as I'd like but I've never used a blade with them.
#2 Build a pull type grader similar to the HyGrade ones Johnson Manufacturing | Home of the HyGrade Pull Type Graders
#3 Build a pull type grader that is a much more complicated version of the HyGrade that rather than a dedicated blade, has a 3pt hookup on it that I could use the same frame and change out the blade for any other of my 3pt blades or soon to be added landscape rake. This obviously is the most complicated but the most fun to build and probably the most versatile.
A question for you grader operators, especially anyone who has experience with something like the HyGrade: With it pulled from the drawbar and the height adjustment coming from the rear wheels, how do you set the pitch of the blade? When I angle my RB, I can adjust my top link to make the blade flat at whatever height I want. I can't figure out how that works with the HyGrade (or others) and seems to me like a significant problem.
Thoughts?
/ Pull type Grader? #2
Put temporary wheels and tongue on your box blade.
Bruce
/ Pull type Grader? #3
If your only doing this once in a while, just build a adjustable gauge wheel for your blade, as for the adjustable moldboard angle on the hygrade some have it as a option , but I don't think it would be a factor for you not to have it in loss gravel.
/ Pull type Grader? #4
I made a blade about 8" high that goes under the tractor just in front of the rear wheels. It has 2 arms that bolt to the 3ph lower arms. Even just straight across it would spread fresh gravel to the sides pretty well, It makes the road smoother like a grader instead of worse like a rear blade. Sorry, no picture, it's buried out in the grass someplace.
/ Pull type Grader? #5
Man up and build an Adams No. 8 copy using a retired NH, JD, or NI hay rake.AdamsNo8-1.JPGAdamsNo8-2.JPG
/ Pull type Grader? #6
I like either option
1 - tail wheel
Or Option 3 - Trailing 3 point for interchangeable Implements. A rear axle from a FWD car and re-worked truck frame would do. You could model it after this.
/ Pull type Grader? #7
Something I came across and was considering building.
/ Pull type Grader? #8
That is a clever design - especially the rear axle tilt. In stead of welding the blade on, I would fab up 3pt attachment points so I could change out implements. Simple clevis type brackets to slide the pins through.
/ Pull type Grader? #9
I had to spread a drive last year with the same scenario. I used my 8' lpgs and made a few passes to knock it down and had a smooth pad. Had the gravel delivered right up the center. Made two passes up and down the center, then two or three passes on each side. Any more than that and I would not have had a crown.
/ Pull type Grader? #10
If you want to build a carrier for grading with a three point implement, watch this guy's videos.
Here's one.
More
Hal Rowley
- YouTube
Bruce
/ Pull type Grader? #11
Here is a clever design
/ Pull type Grader? #12
There seems to be literally hundreds of designs of driveway maintenance equipment,,
and all of them are trying to duplicate the results that you get with a landplane.
You need tractor weight, attachment weight, and a way to control the two.
I do have a larger tractor than the OP,,, so, I can not say first hand that a landplane would be best for him.
The landplane is perfect for me.
/ Pull type Grader?
Bruce
Box blade won't help move the material sideways very efficiently.
I'm liking that tail wheel option. I hadn't thought of that route, only blade mounted wheels.
Sounds like a neat idea
Man up and build an Adams No. 8 copy using a retired NH, JD, or NI hay rake.View attachment 501477View attachment 501478
Ya, that's looking just a tad more complex than I'm after
That's a nice little machine. I saw that tilt mechanism on something else while I was searching. I like the pivoting hitch also. I was thinking draw bar mounted but that would certainly allow for the tilt easier.
I like the front hitch of this one. Possibly fab up one of these for a tongue to attach to the 3pt of the blade and add adjustable tail wheels like the Landpride ones crossed with what IT posted.
I view it differently. Yes, hundreds of designs but they (including a landplane) are trying to copy a true road grader. My landplane is only 3' wide and 600lbs, I'm not a huge fan.
/ Pull type Grader? #14
I well remember your first post before building the 3' land plane. Your wife wanted to preserve the single path with grass in the middle.
Now you are reworking the drive and will need to smooth out the entire drive and add a new base. A larger land plane makes more sense. I recommend keeping a rear blade for shaping and a wider land plane for finishing.
It is pretty simple to me that you and the wife need to decide which is more important, the look of the single track drive with the grassy center strip or a smooth drive that you can maintain easily. A single track drive may be more attractive to some but will require a rework from time to time. A wider drive double the width of the track of the vehicles allows you to drive over the entire drive surface width. This reduces the effect of having single tracks and their ruts over time. Much easier to maintain but may be less appealing.
A land plane is not a road grader by any measure, two different tools. Having a 3' wide land plane does not give you much to compare to. I have a 4' and an 8' land plane and use them for different needs. I also use a rear blade, box blade, landscape rake and heavy roller. Have two sizes of each of these attachments. A rear blade with wheels is also a good implement but do you have the need for this on one home owner drive?
/ Pull type Grader? #15
Thoughts?
If you look closely at the pics you can see they have a cylinder to set the height of the blade with the rear tires. They also have a cylinder to tilt the blade table side to side. A necessity.
/ Pull type Grader?
I was hoping you'd chime in.
Blade height set/adjusted with the rear tires. Check. But if it's pulled from the fixed height of drawbar, that effectively changes the angle of the beam when looking at it from the side, and in turn, when the blade is angled full will change the angle of the blade when viewed from the side so it won't always be cutting 'flat'. Height adjustments will have more effect on the end of the blade that is closer to the wheels rather than moving in a parallel motion relative to the gournd.
Will that same tilt cyl like the one that IT posted compensate for that? I was thinking it was meant for contouring or ditching.
/ Pull type Grader? #17
It will accomplish both, setting the cutting edge "level" side to side and allow the blade to be tilted for ditch digging. How much is unknown with the info we have.
You are ontrack in understanding that raising the blade using the rear wheels changes the fore/aft pitch of the blade's table. Same as shortening/lengthening the top link while using a 3pt rear blade. To properly use a hydraulic top link you also need a hydraulic side link.
/ Pull type Grader?
Thanks for that clarification. So with being able to adjust the table side to side, that presumably is how you can compensate for the fore/aft tilt of the table when the blade is angled?
You lost me there. Care to elaborate?
/ Pull type Grader? #19
I think ovszd has it right. My theory is that you would be building an elongated trailer (implement caddy) with a elevated hump in the middle to accommodate a 3pt implement. Ahead of the implement, you have a "remote" set of 3pt arms and a top link. It would move your rear blade (or box blade, landscape rake, etc.) in the same manner as when hooked up to your tractor 3pt linkage.
You would adjust the angle of the blade / (left to right) by removing the pin on the back of the blade and swiveling to the desired angle.
You would adjust the tilt of the blade ~ ("ditching or crown") by lengthening or shortening the 3pt lift arm. (your rear blade may also have its own tilt feature)
You would adjust the "caster" (blade leaning forward or backwards) to a limited degree by lengthening or shortening the top link. My experience is that this isn't so critical for our purposes.
You would put a horizontal drawbar across your tractor 3pt arms, and that is how you control the height or aggressiveness of the cut of the blade.
In other words all the blade adjustments except height are replicated with the 3pt arms built into the implement caddy.
If you don't like manual adjustments, you could replace a lift arm and top link with hydraulic cylinders. I find when I have the angle and tilt set on my pony grader, I seldom have to change them. Having the blade in the middle of a longer wheelbase is where the magic happens.
/ Pull type Grader? #20
Yes, the fore/aft tilt of the blade table changes as the rear wheels are raised/lowered. This tilting doesn't matter if the blade is set straight. If it is angled at all things change quickly. The side tilt cylinder would correct that problem.
In reference to properly using a hydraulic top link requiring a hydraulic side link: When using your 3pt rear blade with a hydraulic top link you again change the fore/aft tilt of the blade table. If you move the table anywhere off level fore/aft you then must raise lower one side of the table to compensate for the cutting edge of the blade not striking the ground level. Same thing that happens when the Hygrade blade is raised using the rear wheels.
Clear as mud right??
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
2025 IRANCH Tire Balancing Machine (A64194)
2025 IRANCH Tire...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2019 Ford F-350...
2015 Ford Escape 4X4 SUV (A64557)
2015 Ford Escape...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
