Rx 7320 check engine light
/ Rx 7320 check engine light #1
mlh29
Lafargeville NY
Kubota B2710hst, Kubota zd323
I have a new to me 2015 rx7320 pcc tractor with 100 hrs. I purchased this with around 80 hrs a couple of weeks ago. Today I have a solid check engine light on and a severe lack of power. I have checked the obvious, and did a parked regeneration but the cel and power loss remain. Has anyone else had this happen, and how may I fix it. Thank you in advance
/ Rx 7320 check engine light #2
It's went into limp mode, you might try a obdII codec reader and see if you can read the code and clear it, other wise you will need to have a dealer Check it. Were you able to do a park regen, my understanding is if the computer is not flashing the park regen light then it will not let you perform one.
/ Rx 7320 check engine light #3
Disconnect the battery maybe the puter will reset ??? What I know about regen you could stick in your eye. But I like to try the simple things first.
/ Rx 7320 check engine light #4
You need to call your local dealer. There is something wrong with the electronic control of the engine. The only thing that will turn off the light and make it run properly is fixing the issue. Your dealer will plug a laptop in to the tractor and identify the problem area. It may be as simple as a loose electrical connector. The port is not OBD2 so unfortunately a handheld code reader will not connect or clear the code.
Do not keep running the tractor as it is running in limp mode. It may only be running on three cylinders or sending out massive soot to plug up your particulate filter.
/ Rx 7320 check engine light #5
The diagnostic connector on my CK3510 is OBD compliant. Why isn't the RX?
/ Rx 7320 check engine light #6
I know that if a regen is ignored so many times that the computer will effectively stuff it into limp mode, requiring dealer intervention. Once you've got this condition any regen that you do will not clear this.
At the very least make sure your dealer is aware: if it can somehow get logged in their records that would be good for any future issues. But I would think that you're now at the point where you have little recourse other than involving your/a dealer.
Dealer has had the tractor since Saturday. I am waiting for a explanation of what is wrong, and then a few days for whatever is needed to get shipped.
/ Rx 7320 check engine light #8
Please keep us posted mlh. I'm having cel problems on a 2015 ck 4010.
/ Rx 7320 check engine light #9
What was the result on your tractor for fixing it?
Ratchet Straps (A62183)
Ratchet Straps...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
LandPride PT 10' Mower (A62180)
LandPride PT 10'...
METAL CRATE OF CASE IH COMBINE PARTS (A63290)
METAL CRATE OF...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
Clemett Tri Axle End Dump Trailer (A64047)
Clemett Tri Axle...
