Branson questions
/ Branson questions #1
Slowpoke Slim
Elite Member
Bismarck, ND
Husqvarna YTH24V48 riding mower, Branson 3725CH
Back to looking at tractors again. Found a sale at my local dealer for a 3520CX. Cab, heat, no AC, 12 spd shuttle trans. Questions are, first the trans, 12 spd shuttle-good, bad, pros and cons? Living on a small place, couple acres outside of town. Mostly need snow removal (for my own place plus a couple more), with some moderate dirt work, grading, driveway repair etc, and planning on mowing my road ditches with a 3pt brush hog, but I also have a few tree stumps I need to pull out. I'm not too worried about the snow removal or light grade work, but the stump pulling... will this rig stand up to that, and have enough grunt to pull a medium sized tree stump? I have a couple large stumps that need to come out, but I don't mind digging around those first. But is that the trans I'm looking for? I don't want to blow the guts out of the transmission on my first stump pull.
Also can this tractor equip an SSLQA setup? I'd *really* like to be able to put a snow blower on the front in place of the FEL, and want the quick release ability to go back and forth between the FEL and the blower, as depending on the snow and which site I'm on, I may need to swap. I strongly prefer not to use a rear 3pt blower, as one of the driveways I will need to clear is pushing 500 ft long and I don't want to back over my shoulder that far (bad back).
I admit the biggest draw to the 3520 is the price, but if it won't do what I want, then the price is irrelevant. Also, the cab is a non-AC cab, which could be ok, but how easy/hard is it to get the glass doors off for warmer weather? Will the standard FEL bucket stand up to normal dirt work, or is their a heavier duty bucket that would stand up better?
/ Branson questions
277 views...
Anyone with answers?
/ Branson questions #3
My 6530 has a F-R shuttle (requiring the clutch but no biggie) and ABC Range with 1234 for 12 F-R plus there is a creep function, separate switch that halves the gear ratio so I have 24F-24R. Flawless performance over the 10 years I've had it. Don't know about the PTO options on that tractor.
I have a rear only and it has a 3 position selector switch for 540, 1000 and half way between. For light duty cutting primarily, you can use the mid range and drop the engine rpms and fuel consumption. The 1000 would be used for specific usage equipment like a belt driven hammer mill to grind up corn stalks and ears.
The PTO is a 24 disc Independent, wet clutch so it is smooth on engaging at rpms under load. The lift has a cutoff switch whereby if activated, when the 3 pt lifts the PTO cuts off till the implement is lowered back down. You can also use it as a "Live" PTO whereby depressing the clutch cuts off the rotation. This is really convenient when running a line of post holes. I have had zero problems with all these systems over the years.
My cab has AC too.
/ Branson questions #4
I don't have a branson and never drove one. I can tell you that a cab with the doors removed will still bake your butt. Mine was way to hot in the sun even up here in New England. My hst trans works the best for my snow blower, shuttle shift tractor was a pain as it was never the right speed. Also, a front mount blower either has a shaft off the rear pto or hoses from the rear oil and pump, therefore not very easy to remove.
/ Branson questions
Thank you guys for the replies.
Do you think I'm better off with an HST or ? for pulling stumps? I'm wondering if 35 hp is big enough, thinking 40 to 50 hp would be safer?
/ Branson questions #6
All current Branson loaders come with SSQA. My 3725 has 540 rpm and 780 rpm pto speeds. The higher pto gear would be 540rpm at about 1800 rpm but Branson recommend running at 2000-2500 rpm to keep the DPF burned off.
The bucket looks pretty sturdy. The upper edge is boxed in to make it stiffer.
I've not used a non HST tractor but it seems to me that HST would be better for pulling stumps and would be more reliable doing it- no clutch to burn out. Posts on this forum about HST probems are very rare... clutch replacements not so much.
/ Branson questions #7
Hey Slim.
I have a 3520H... hydrostatic transmission... my first tractor.
Regarding stump pulling, I bought mine in part because I have a lot of stumps to pull. Unfortunately these are California Live Oaks and being a drought resistant species, the tap root and root system is ridiculous. I'm reminded of the scientific fact that 90% of an iceberg is under water. With the backhoe I've done a lot of excavating around these trees but even with that I've snapped a chain, and bogged down the tractor. The Branson is definitely heavy enough especially with 800 lbs of rimgard in the rear tires and the backhoe attached but even a much larger machine wouldn't have the power to get these stumps out.
For context I'm talking about oaks that are about 12" diameter breast height as a forester or arborist would measure... I was an arborist for 10 years and grinded out a lot of stumps so I was surprised at the difficulty of removing these particular ones. My next thing is to use block and tackle to multiply my mechanical advantage... and I'll probably need to get into the excavation with a good battery sawzall to cut roots as I pull... it'll be a bit tricky and dangerous.
Getting back to your situation, it would depend on the type of trees but regardless of species, I don't think you'll be pulling too many trees out on brute force unless they're in the 6" and under group.
Good luck.
/ Branson questions #8
I think if I were stump pulling I would get a tractor with a back hoe and dig them out. Trying to use the FEL to dig them out to me would be very hard on the front axle assemblies. Trying to pull them out with the draw bar could lead to a reverse flip over and if not using the drawbar but using the 3 pt WILL lead to a reverse flip over that you probably wouldn't survive, or if you did your tractor operating days would be over!!!!!!!!
/ Branson questions
Can you tell me if I would have to add anything to the SSQA loader to get the blower attachment to work on it? Extra control only, or do I need a separate hyd line connection to make the blower spin/chute rotate?
/ Branson questions #10
You'd need a diverter valve or 3d function valve to operate the hydraulic chute control. Your dealer should be able to do something for you there. Or you can get the WR Long 3rd function kit, or assemble your own- there's some threads in the hydraulic section.
/ Branson questions #11
A hydraulically spun blower takes a lot of hydraulic volume, and most compact tractors do not have enough. You see them on skid-steers but they often have 20-30 GPM pumps, large hydraulic tanks and hydraulic coolers to keep the oil from getting too hot, and they run large lines/hoses for the hydraulics. You will not have the capability to spin a front mounted snow blower with that tractor unless it is mechanically driven. If mechanically driven, it does not typically mount to the loader. It has it's own sub-frame and a shaft runs under the tractor to the rear PTO, which has a "drop" on it to get the power down under the tractor and also to allow for some gearing to get the speeds correct. You then run a hydraulic or an electric chute rotator and possible deflector.
What you are wanting is ideal, and makes sense, but you have to go to a pretty good size tractor to get 20 plus gpm off a remote. Lot's of guys run the blower on the back and a plow on the front and plow all they can and blow when they must. That way you are carrying both snow weapons! But there is no doubt that backing up is hard on the back/neck.
HST is probably best for snow blowing, or a tractor with a couple more ranges. We recently sold a 100 HP Deutz-Fahr to a guy that professionally blows snow, it had a 40 forward/40 reverse hydraulic shuttle. If he can't find the right gear, he isn't trying hard enough.
/ Branson questions #12
Hey Slim.
Good luck.
Lots of wisdom in those words Bob. Years ago before I had my first tractor, I borrowed a 90 HP Case from my dad. I tried to pull out a 6" live oak. I wrapped a chain around a cross bar between the three-point lower arms and lifted. I snapped the chain. I got a bigger chain, snapped it. Got a bigger chain and did a wheelie. Finally dug and chopped the tap root. BTW, doing what I did was dangerous. I was a kid, and did not think about a rear rollover or flying bits of chain.
But I can go to a 16" Pistachio tree and push it over pretty easily with my skid-steer. Many trees can be pushed over pretty easily. Try that on an Oak and it's a joke. Now I have an excavator, but on oaks you still pretty much need to rip through the tap root or its not coming over.
The type or tree, the type of soil and the moisture level in the soil are all significant factors. Sometimes it is best to cut the tree at ground level and grind the stumps.
/ Branson questions
Thanks Dave, my local dealer pretty much confirmed what you said. I finally was able to get time to visit with him yesterday. So, I'm rethinking my needs a bunch. Kinda hard to let go of the idea of swapping front blower for FEL and back, but that's how it is. I'm sure I don't want a skid steer, so... But, being able to look over the tractors in person yesterday (finally), I think I've got my mind made up on a 3725CH, with cab, heat and AC, a 3pt 6ft brush hog, a box blade, and probably order a piranha cutting edge, maybe some edge tamers, and possibly a set of clamp on forks.
He had the 3725 sitting there, and I was able to get in it and drive it around a bit. I think it's the one I'm going to go with. Hopefully will have time to call him back tomorrow (couldn't get time today). We haven't talked financing or warranty yet, so we'll see.
/ Branson questions #14
Slim, great choice of tractor. On the forks, skip the clamp-on and go with a set of quick attach skc style. The clamp-on forks are great if you do not have the quick attach bucket, and great at lower capacity levels, but for this tractor I'd go with the real deal forks.
/ Branson questions
I hear you Dave, just trying to cheap out (a little bit) :laughing:
I'm sure I'd end up getting the real SSQA forks eventually, but to be honest I don't need forks much, would come in handy for setting my 5th wheel hitch in and out of my truck bed though. My hernias "speak to me" every time I have to take that thing in or out.
/ Branson questions #16
I bet the cab version of the 3725 is really quiet inside. I'm still marveling at how quiet my open station 3725 is.
/ Branson questions
It's very quiet, even under load. Smooth, very little vibration, even has that "New Tractor" smell.
:D
We'll see if we can put the deal together today.
/ Branson questions #18
We probably sell 50-75 sets of clamp-on forks a year, so they for sure have their place in the scheme of things. What I don't like is that when lifting odd shaped objects the forks want to splay outward or inward unless clamped really tight. Not an issue if you are lifting pallets. And the load is 18" or so further forward, diminishing capacity. But for your hitch, they would work great.
/ Branson questions #19
I agree on passing on the clamp on forks and going for the Qa from the start. You may not think you will use the forks all that much now, but you will be surprised at how much you end up using them. My forks are on 80% of the time compared to the bucket.
For the stumps that need removing on my place, I cut them close to the ground and rent a stump grinder from Home Depot. Disposing of a big stump is not easy, and burning one a hassle.
/ Branson questions
I know. It's like when you buy a brand new hammer, everything starts to look like a nail.
Well the deal is done. Papers are signed. Dealer will fill the tires with Rim Guard, weld on some chain hooks onto the bucket, and deliver it to my place next Saturday (I'm going to be out of town most of next week).
I purchased the tractor with FEL, box blade, brush hog, trailer hitch, draw bar, and clamp on forks.
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Freightliner Columbia (A63689)
Freightliner...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
