I'm starting to read up on it. Seems the light current "minder" type devices come with and without high current pulses that are designed to resonate with oxide flakes on the plates and turn them into Pb and H2SO4, causing them to fall to the bottom of the battery.
In reading I find that "fully" charging a battery helps extend the life too and a lot of chargers (not sure where minders fit in) don't fully charge the battery or batteries that get charged overnight don't get fully charged for usage the next day usually....as I read.
I have a large capacity battery I removed from my 6530 after 10 years because it started slowing down on cold starts. For grins, I have been fooling with it somewhat. I have a Schumacher 10A auto/manual charger. I noticed that the charger turned on the "charged condition met" green light when the battery was still drawing around 4 amperes. I left it on for a day and checked again and the amperage was down to 2 amps. Will check again today and see where it is.
In reading on the subject, there are no definite conclusions as to just what happens inside your battery. Lots of theories I read, but nothing set in concrete to be used in all instances. So for now, I just keep the little $10 <1 amp. trickle chargers on my seldom used equipment.
