Another ECU update letter?
/ Another ECU update letter? #1
countrybumpkin
Elite Member
Kioti, kubota
Received a letter from Kioti today stating my NX needed to have a ECU update for the emissions by March 17, anyone else received one? I had a update done about a year ago for the same type of issue, it was related to issues at altitudes above 5000 feet if I remember correct. Bad thing is my local dealer past away and they closed the business so my next two or three are just over a hour away, not sure if they will send a tech out to do it or expect me to haul it in.
/ Another ECU update letter? #2
I got one also for my dk5510. So what happens if I cant get it in by March 17th? My dealer is also an hour away. I might try calling them and ask if they can come out!
/ Another ECU update letter? #4
I have not received any such notification. I'd been corresponding with my dealer about some other things just this week and no mention.
Man, my tractor has been working really well, I'm really not wanting to have it touched!
/ Another ECU update letter? #5
Ditto!! I've received both letters and have not had the update done. My NX4510H is running without the periodic drop in power or the CEL coming on which it had been doing earlier in the tractors life (a year ago). Neither is it going into regen. I tried to regen manually but nothing happened. Don't know if this will cause later problems or if it's even related to the update but the machine is running great now - I'm hesitant to let someone "correct" this.
You can't just press the regen button and do a Manual regen anytime you want, the light must be blinking to do a manual regen. How many hours do you have on yours now?
/ Another ECU update letter? #8
If you have already had the ECU update done than you are fine. I am not aware of any new updates. All dealers had to report back to Kioti with sign off sheets that each tractor was completed. If Kioti has sent you another letter than it means that they are still showing your tractor as not completed. You may want to inform your dealer that Kioti sent you another letter and needs to be informed that your tractor is completed.
If your tractor has not been done than please call your dealer to arrange. I am not aware of any changes in operation or power caused by the update.
/ Another ECU update letter? #9
You can do a manual regen at anytime. Tractor just needs to be at running temperate and parked. Then hold the button down and the manual regen will start.
I'll have to try it again some time then, I've never been able to get it to work, and was even told by the dealer back after I Bought it it would not work. I really have no reason to do one, but would be nice to if I did.
/ Another ECU update letter? #11
Man, I love my old tractors. Pumps diesel, sucks air, runs. Don't need no stinkin' computer. :dance1:
/ Another ECU update letter? #14
My old diesel cars, MKIV VWs, and their computers work really, REALLY well. No computer issue at all. And, the computer is actually able to inform me of errors.
I'm no techno-head, but I'm also not a Luddite (though I've tried!).
No ECU update on my tractor. No issues. And, being newer, it's quieter and doesn't stink like older non-ECU equipment.
Time will tell: my cars have proven themselves (I have five of them in the family). At the rate I use my new tractor I don't figure I'll come to a time that it'll be an issue either.
My truck, and IDI, which can sit for months at a time, has zero electronics (well, it has a GP controller, but even if that shat it'll still start- if need be just plug the block heater in). I appreciate this. And, my B7800 has no real electronics either: it's also an IDI. And my generator, Kubota powered, is also an IDI, though, it clearly has electrical stuff :D
If I was computer adverse (and I have plenty of reason to be) I wouldn't be typing this here... I once made like Hunter S. Thompson and shot a typewriter!
Kioti sent another letter , certified this time, saying the update still needs done and to have it done by June 16th. I completely forgot about the other letter and never called the contact person, guess I will this time and see what they say. I'm sure it's the update that was done last spring.
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
15ft. Hay Rack (A65640)
15ft. Hay Rack...
2017 Scag 72" Zero Turn Mower (A64194)
2017 Scag 72" Zero...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
