Trailer demo.
   / Trailer demo. #1
jack707
up North wisconsin
farm trac 555
Just started a few days ago as you can. First thing is disconnect the propane from tank. Take the windows out before demoing then when that's done start siding. Now here's the question what is the best way to take the roof down?
   / Trailer demo. #2
Best way to remove the roof and take it apart is with an excavator with a thumb.
   / Trailer demo. #4
Turn off power at street, break light bulb glass, hook up propane tank, open valve, turn on power...
-R
   / Trailer demo. #6
I demolished a mobile home once. Half of it was burned in a fire. The rest I pushed on the walls with the loader until it fell over. Once it was down we cut it in small enough pieces with a chain saw and loaded it into dumpsters. There was a burning ban so we had to haul it away.
   / Trailer demo.
I have a few on my tractor so that a possibility. I was thing of cutting some holes and put a strap thru a pull with my 2500 this way the shingles would be on the outside
   / Trailer demo. #10
If you are taking it apart by hand start with the roof and then do the walls. Roof won't fall down if the walls are intact.
2013 Ford F-150 Pickup Truck (A55788)
2013 Ford F-150...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2003 Freightliner Ambulance (A55788)
2003 Freightliner...
Terex TB44 44ft Telescopic Boom Lift (A55851)
Terex TB44 44ft...
