Working EA Pine Straw Rake!
/ Working EA Pine Straw Rake! #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
An action video of the EA Pine Needle Rake is something we've never made, but I found this one on YouTube earlier.
It's on a TURBO John Deere 1025R of all things. :eek:
Check it out.
Travis
He talks more about the turbo and gives the rake a quick run in this video.
/ Working EA Pine Straw Rake! #3
This Pine Straw Rake (EA) works real well not only on Pine cones and needles, it is good for general clean up after downed tree debris, sticks, leaves and even trash. Had it since 2013 and used many times at my place and at neighbors'. It has held up well.
I do wish that it was designed to fit my Quick Hitch. Thus I have to remove the QH, install PNR then reattach the QH.....I hate that. What say you, Travis?
Glad to hear it's working good for ya!
I've received a couple of emails requesting a QH compatible PNR from some guys over on the JD forum.
I think it'll happen, but i have no idea of the timeline. This year is starting out like no other, so time is what we're lacking!!
Travis
/ Working EA Pine Straw Rake! #5
You could still keep the top holes where they are for the higher lift if someone wants, and then have a lower bolt-bushing at QH height. And bottom pins to match QH location, if not already.
Bruce
Bruce
I agree. It will be a pretty simple change. I'll mention it to Ted & see what he says!
Travis
/ Working EA Pine Straw Rake! #7
006.JPGIIRC the bottom clevises that hook to the QH almost fit. If I was a handy welder fellow, I could probably do it myself. The picture is just for fun. The needles etc still have to be forked up into a wagon to haul away, burn or use as mulch.
Cheers,
Mike
View attachment 499773IIRC the bottom clevises that hook to the QH almost fit. If I was a handy welder fellow, I could probably do it myself. The picture is just for fun. The needles etc still have to be forked up into a wagon to haul away, burn or use as mulch.
Cheers,
Mike
Nice!!
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
