/ Harbor Freight Tools that don't suck #6,881
New toys!
I found the deal of the century, a Harbor Freight MIG 180 welder, current model 68886 and a Grizzly tig/stick welder from someone who had upgraded and sold these ridiculously cheap. I've checked out both, both run as they should. The HF has had all the modifications that enthusiasts perform on these: longer and heavier gauge 220 volt power cable as well as replacement heavier, longer 10 ft stinger and ground cables. A switched jumbo capacitor added, then the guy got carried away with a modification for smooth running of a 10 lb spool. I ordered a replacement standard spool holder so I can use up the several 2 lb rolls of flux core I have on hand. Finally he put in a solid copper bussbar in place of the factory jumper so I need to make a jumper for the DCEN (electrode negative) that flux wire calls for. I don't see anything else that it needs to put it in service.
The Grizzly welder is interesting. Grizzly imports decent machinists stuff but this is an orphan, no support available. I hacked up a plug to replace the twist-lock I found on it and tried it out, it works fine. A proper plug has been ordered.
I commented on these over in the welding forum
but I expect more people familiar with the HF Mig 180 will see my description here. What can anyone tell me about the HF - or the Grizzly?
/ Harbor Freight Tools that don't suck #6,882
I found a HF tool that seriously DOES suck. It's the ratcheting PVC pipe cutter.
Finger Release Ratcheting PVC Cutter
It is so flimsy that the blade deflects when about 1/2 way through a piece of 3/4" pvc, and you wind up with an angled cut. And the tool was brand new.
I knew it couldn't be very good for $6.79, but I thought it might be ok for a few cuts. Nope. Back it goes to the HF store.
/ Harbor Freight Tools that don't suck #6,883
Hey Pappy, make sure you tell them the tool sucks and it wasn't just a 'rental return'. They need that feedback. I sort of know the manager at our closest HF and he said they need to know the difference and often people don't say so they assume it was just used for an odd job.
/ Harbor Freight Tools that don't suck #6,884
HF must have a new supplier. I have a blue one I bought there 5 years ago that works as intended, on 3/4 and 1.25" pvc pipe. It seems a little flimsier than an expensive pro tool but it makes clean, square cuts.
Agree, when you take an unsatisfactory tool back, tell them what they got wrong. I did this recently with both a hand-held belt sander and also the 4" belt plus 6" disc combo benchtop sander.
/ Harbor Freight Tools that don't suck #6,885
HF must have a new supplier. I have a blue one I bought there 5 years ago that works as intended, on 3/4 and 1.25" pvc pipe. It seems a little flimsier than an expensive pro tool but it makes clean, square cuts. . . .
Mine is a black one like shown in the link. So, I think you're right - i.e., they changed suppliers.
This one sucks for sure, and it's going back. But all the good ones I've found are really expensive, and I don't do enough with PVC to justify the cost. I may try the Husky one from Home Depot and see if it works any better.
/ Harbor Freight Tools that don't suck #6,886
I have a red one that is all metal and works fine. I think that it came from Home Depot, but the only marking I can find on it is "Taiwan".
/ Harbor Freight Tools that don't suck #6,887
I have a yellow one from many moons ago works okay for me...have cut a lot of back poly pipe with it. Cuts straight thru the thinner wall stuff easy enough.
Does seem to cut crooked on thick stuff like sched 40 pvc conduit if you try squeezing straight thru it. Working it like a pipe cutter and rotating the tool around the pipe helps a lot to get a straighter cut.
Harbor Freight Reviews - Ratchet Action Hose/PVC Pipe Cutter
/ Harbor Freight Tools that don't suck #6,888
I found a new use for the freebie magnetic flashlight.
I keep a couple stuck on my utility trailer that I store in a tight barn stall. Aside from general nightime use, when I have to back the trailer into its stall I stick the magnets on the back and side of the trailer to light up the wall so I can get the trailer close to the wall without gouging it.
Haha back up lights hey :D
I know what you mean about having a hard time seeing far back parking a trailer. I had to wire in backup lights on 18 ft tandem axle so I could see what I was doing after dark :rolleyes:
/ Harbor Freight Tools that don't suck #6,889
Just don't put them in anything you care about and leave them there long enough to leak and corrode.
I got some of the free batteries once. Put them in my camera and got the "low battery" warning from the get go. Not enough power to operate the camera, so not much good for flashlight either. Never bothered with them again.
Even Duracell batteries will leak when discharged, so I try to remember to remove all batteries from things that get tossed in a drawer for use "someday".
/ Harbor Freight Tools that don't suck #6,890
The media leaks can be fixed easily with a little silicon or poly urethane sealant. Most importantly, you need negative pressure in your cabinet. Those that try to blast without sucking enough air out as exhaust are the ones who ***** like he11. Not the cabinet's fault.
Oh, "media leaks" - - gottit, EVENTUALLY.
Giyi Gy-72Pro QA Mulcher (A60463)
Giyi Gy-72Pro QA...
2016 Terex RL4 S/A Towable Light Tower (A60352)
2016 Terex RL4 S/A...
2005 Ford Excursion 4x4 SUV (A60352)
2005 Ford...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2022 Kubota M5-111 (A60462)
2022 Kubota M5-111...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
