Diverter valve mouting ideas.
/ Diverter valve mouting ideas. #1
ticolawnllc
Bob Cat CT120
It's got my diverter valve. Can any one help out with mounting ideas.
I'm looking to mount on the loader arm. On a bobcat ct 120
/ Diverter valve mouting ideas. #3
Drill holes in the loader arm and tap them. Bolt it on and done.
Pay attention to the orientation and where your IN/OUT hoses are gonna go, and mount it logically.
Drill holes in the loader arm and tap them. Bolt it on and done. Pay attention to the orientation and where your IN/OUT hoses are gonna go, and mount it logically.
other than the in and out puts does the orientation mater.
/ Diverter valve mouting ideas. #5
Nope, a couple thousand pounds of hydraulic pressure will overcome gravity (14.65psi, roughly):D
Main thing with most diverters is their connections and coil need to either be somewhere NOTHING can get to them (most delicate part of the diverter) or else fab a protective cover, whichever is more practical...
You may find that the best way for hoses (if yours are like mine) is to use straight adapters from port (mine are SAE) to hose (mine are JIC) - this makes it easier to put angle adapters on so you can "point" your hoses where they lay better. Several of the diverters' ports are too close together to put 90's directly on the ports, because the 90's will interfere with each other when you try to tighten them... Steve
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2020 Solar Tech Silent Advisor S/A Solar Towable Radar Trailer (A61572)
2020 Solar Tech...
Kubota GR2020G (A63688)
Kubota GR2020G...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
