California Drought
/ California Drought #161
This photo was taken yesterday morning when the spillway was shut down for inspection. It shows the exposed bedrock below the concrete, and I think I can make out some rebar in the concrete. Keep in mind you're looking across about 200' of material, 2/3 of a football field, so small details like rebar are gonna be difficult to see. Easy to understand that the water will continue to undercut the spillway concrete, but once it reaches rock it's not gonna go very much deeper.
Wow. I don't know anything about concrete, but retired from Caltrans (auditing contractors mostly) so I'm interested in this stuff. In my (uninformed) opinion the contractor there cheated and that looks like substandard concrete base beneath the spillway surface. The only time I've seen similar is third-world sidewalk that disintegrates after a couple of years. Do we have a civil engineer or concrete lab tech here who can support/refute this theory?
/ California Drought #162
I was thinking the same... I don't see any rebar on the spillway base.
/ California Drought #163
Some pictures of the broken concrete:
Source: Oroville Dam Spillway Failure | Metabunk
Aaron Z
/ California Drought #164
PGE is rerouting a power line tower with helicopters and trees on the emergency spillway are being removed... it had not been maintained and never used per news reports.
Looks like some bought into it would never rain again in California.
/ California Drought #166
Anyone doesn't think this is a major failure and is just a small problem, is just who you don't want to listen to.... Because it is.... A warm spring and all that snow pack coming off in a month combined with rain, and you've got a disaster, and yes with enough water undermining this the dam might not fail but the whole thing could cut a new channel around the dam, real fast.
/ California Drought #168
Metabunk. Never heard of it before but this looks like an excellent analysis. Have you linked to Metabunk on prior events/issues?
Nope, just ran across it the other day looking for more info about the dam spillway problems.
Seemed well thought out, so I have been watching for updates.
Aaron Z
/ California Drought #169
Where that damage in the spillway was is now a huge hole in the spillway and they just started putting water over the backup spillway this morning about an hour or so ago. One thing about living in CA is that you either have too much water or not enough of it so it's always on your mind or 90% of the time anyway.
A huge mudslide closed I 80 yesterday in both directions so they were running all that traffic on CA20.
Last night thousands of eastbound cars were running by the house on Scotts Flat Road trying to avoid the backup on 20 while they held all the big rigs leaving them with no place to go. I suppose because of the snow on CA20. Twisty, windy narrow roads with snow and trucks don't mix too well I guess. Hwy 49 is also closed just outside of Nevada City due to mudslides on both banks of the Yuba River. It's like hotel California around here, you can check it but you can never leave.
/ California Drought #170
We shall see where it goes. From what I understand the spillway and the emergency spillway are over an outcropping of bedrock so the water shouldn't be able to channel away enough to damage the dam itself or let water go around it uncontrollably.
That said, it will be a big project to fix it.
Aaron Z
/ California Drought #172
And some people just won't be happy until there is such a catastrophe.
Though I wouldn't be endangered by such an event, it would have a dramatic impact on me and my immediate neighbors. And the death tole in Oroville and the surroundings would be huge. People here are preparing as best they can, and sure as He11 don't need a bunch of Chicken Littles adding to the confusion. Mr. Scott, if you don't have any factual information or positive ideas to contribute, I for one would appreciate it if you'd just keep your rumors and dooms day predictions to yourself.
/ California Drought #173
You should be busy building your ark instead of wasting your time on this board. LOL
If end up not needing the ark you can always use it to store water for the next drought which will be here before ya know it.
/ California Drought #174
So.... I'm just sitting here reading all this and wondering what the issue was with using the emergency spillway. So here are some facts, the dam is an earthen dam, I.e. Dirt and rock filled, not solid concrete. The emergency spillway is built right on top of this earthen structure, by the same outfit that built the spillway on top of a rock base. I did a search to see about the geology of the ground the dam was built on and really found nothing. Many people are using the term bedrock. I think that is an assumption that may not be correct. In mountainous areas the term granite is used as the bedrock is usually thrust up. I don't see much granite around. I see a lot of dirt.
Now I understand why they don't want to use the emergency spillway.
/ California Drought #175
The main concern I've heard expressed with respect to the emergency spillway is the additional debris and mud that will be dumped into the Feather River. If you review the Metabunk links posted earlier in this thread, you'll find that both the main spillway and emergency spillway cross rock outcroppings where they meet the reservoir, and the rock extends quite a way down the hillside if not all the way to the river. Keep in mind that all of this area was laid bare to bedrock during construction of the dam. As you say, there is little to no granite in the area, it is primarily limestone and what the locals call shale, I think geologists would call it schist. It's a strong metamorphic rock formed when sedimentary layers are subjected to tremendous heat and pressure. My home is built on it, and my neighbor would be the first to tell you it's very tough to get through with a bulldozer or backhoe. The Metabank pages show outcroppings of these rock strata that underlie the main and emergency spillways, about half way down the first page. If you search for photos showing Lake Oroville during the drought summers you'll find that the canyon walls are quite steep all the way around, an indication that the river had to work very hard to cut down through those layers of rock. I have confidence that the engineers and geologists that sited the dam spent a lot of time understanding what was under it and how water flowing in all of the spillways would interact with the geology of the area. We're not talking roaring twenties engineering like that that dominated much of the dam construction in Southern California and led to some spectacular dam failures. Construction of the Oroville Dam didn't start until 1968, and planning went all the way back to the '50s.
I also think there's reluctance to be the first to use the emergency spillway, even though the engineering and construction methods seem sound. The proof is always in the pudding, and now we're getting it. Let's hope it turns out like the Y2K fiasco, another tempest in a teapot.
/ California Drought #177
Terrible journalism. "officials at Oroville Dam took the unprecedented step of opening the lake’s emergency spillway. "
Really? How did they open it?
/ California Drought #179
No limestone.
Geology there is complex. The western slope of the Sierras is a chaotic jumble resulting from two major tectonic plates pushing against each other and causing uplift. Terrain from diverse geologic eras can appear right next to each other, separated only by slip lines that can be near vertical.
I have a gold mining claim 40 miles NE of there, up a tributary perhaps 150 river miles upstream. Bedrock there is serpentine which is sedimentary layers compressed and aged into laminations that are near vertical instead of horizontal due to this uplift. Modern streams have cut down to this bedrock, and the streams carry gravel bearing gold nuggets (we still find a few, the '49ers got most of them). This gravel is the streambed residue from a far larger prehistoric river that the modern streams intersect. (And in my area a lava ash cap from Mt Lassen, similar to concrete, overlays all this). The mines in my region generally extract this ancient streambed gravel and crush it, in contrast to a hardrock mine.
The dredger tailings hauled up the Feather River Canyon to build that dam were the output from floating gold-extracting dredges that operated up until WWII in the area below the present dam, processing ancient river gravel that deposited down there where the Feather River velocity slowed.
Its complicated. Those hillsides surrounding the dam are likely hard enough to not erode, but a perhaps greater risk is an earthquake that shifts land along a fault line. Filling the reservoir led to a couple of earthquakes. Who knows what stresses are building with the reservoir now full.
/ California Drought #180
No limestone.
Nice informative post, Cali.
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
ATTENTION! PLEASE READ (A64126)
ATTENTION! PLEASE...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
