How do you get 600 ft/lbs torque on a rotary cutter blade nut?!?
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #1
Herkypilot
Meadows of Dan, VA
Kubota M7060 HDC12, KX040 & L3540 HST
I'm doing some research for the inevitable blade replacement on my Bush Hog. The owners manual calls for 600 ft/lbs of torque on the blade bolts and 450 ft/lbs on the blade holder pan. I'm not sure how to get that amount of torque with any tools I've researched. I don't really want to spring for a 3/4" high impact air wrench (along with the compressor to run it). Any other suggestions?
Thanks,
HP
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #2
Big breaker bar and a pipe.
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #3
This^^
A 6' pipe with 100# of pressure on it will get you 600ft/lbs. Probably gonna need to spring for a 3/4" breaker bar and socket, though. Harbor freight has pretty cheap 3/4" socket sets with a lifetime warranty. I don't use my 3/4" set very often, but when it's needed it's sure helpful.
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #5
Google "Torque Multiplier".
Looks like you can get a Chinese unit for less than $100. The pro level units will be north of $300.
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #6
Put on 60 lbs torque ten times.
Bruce
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #7
Good impact gun and Kentucky windage is all I ever used when I saw numbers like that. Decades of doing that and never a failure so I guess it worked.
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #8
My spec was 480 foot-pounds. I used a 6' piece of iron pipe--3/4" pipe, as I recall--run down over a 24" breaker bar. Then I put a scale on the end of the pipe and put 80+ pounds of force on the end of the pipe.
   / How do you get 600 ft/lbs torque on a rotary cutter blade nut?!? #9
Plenty of 1/2" drive HF impact guns are over 600 ft lbs. They have at least 3 that range from 600-1150 ft lbs. The HF Earthquake one I have goes up to 800. My Chicago Pneumatic (USA Made) only goes to 450. You should have a 60 gallon or larger compressor to run them. Not sure what or if you have a compressor. To torque them using a torque wrench you'll have to go with a 3/4" drive torque wrench.
I figured the opinions would be varied and interesting; especially bcp - "Put on 60 lbs torque ten times." Even more, looks like several use the TLAR method or That Looks About Right. ;) I know there are quite a few that have many years of experience and I wanted to see if anyone had problems with just using a large pipe to crank on it.
Thanks for the replies guys.
HP
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
