Robotic Following Cart to Replace Light Duty Tractor Tasks?
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #21
I understand Lean Startup methodology. I've read Steve Blank and while I absolutely agree with his belief, you have to be open to what you are being told as well.
I don't think you are dreaming, but I do believe you are looking for a cure without an illness.
A Gator, can haul you and more than 250lbs. While it can't return, given that it can haul significantly more, it can do in a single trip, what you are envisioning several trips with your machine.
The thing is, that in your instance of produce picking... there are already multiple alternatives which fill the role. This has been pointed out and videos linked.
When the Stanford Students built the 'weed killing robot', they paid attention to what the growers were saying.
Pivot or Proceed: How to Decide | Kauffman Entrepreneurs
Dadnatron, thanks for the feedback. We are looking for feedback and listening. I was just pointing out that our product doesn't look like a product you would buy yet because we are trying to establish proof of concept before we invest and build.
In the case of a Gator, you still have an operator doing a trip. With our idea, the operator could pick instead although there might need to be someone to unload the machine at the home point if the cargo could not be dumped.
Do you have any job where you are walking along picking or unloading smaller items, and could use a cart that could follow and then return to home/come back? Sounds like no. Is everyone doing a similar operation to you?
One other question, when you refer to Weed Killing Robot, do you mean Blue River Technologies or a different company? I was unaware that there was a weed killing robot available today that had had widespread commercial success which is why I ask.
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #23
Aaron,
Thank you for the information - really helpful! Tracks are very do-able, albeit at a higher cost.
Have you ever seen how they are pruning the trees? In your area, do they typically remove the pruned pieces to avoid spreading disease etc.?
Do all of the operations that you know of have such large scale bin trailers for harvesting where workers pick directly into them? Conceivably, our robotic carts could make a 1-2 mile trip from picker to collection point and back which might replace some of that use. Best not to try to attack a mechanized solution however so if that usage is everywhere perhaps we are off base.
Small operations would just use a 3 point forklift mast, 3 point forks or a forklift mast on the front of the tractor. Anyone with multiple crews will probably be running some sort of bin trailer. From what I hear, a couple of 4-5 person crews can keep a bin trailer operator busy
Pruning trees, they will use a front mount brush rake to clean up the trimmings. Usually it looks something like:
Source: http://edwards-equip.com/wp-content/uploads/29-brush-rake.pdf
Then they mulch whatever is left next time they mow the orchard.
Aaron Z
Aaron Z
Aaron, good to know, thank you, so probably no utility on large scale apple picking operations as everything is being done so heavily with orchard tractors etc. It just seems so useful on a smaller scale operation like the one my family has (about 15 acres of apples) where we don't have those types of systems. Probably too tiny to justify though.
Do all Apple operations simply drop pruned materials to ground, and then windrow to center or capture in center of row with one of those rakes? I would think this would create disease issues as not all material could be removed, which I why I ask. With a system like ours, conceivably the pruning worker could prune into a bin, and have all of the material transported off site, reducing the risk of spreading fire blight etc..
What about grapes, hothouse tomatoes, mushrooms, and other environments like those where there are smaller lugs of material that people are picking into and have to transport back to central depots? Any thoughts on potential pain in moving materials there? (settings such as this: Wine-Harvest.jpg)
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #25
I don't know for sure. I suspect that your machine would be too small (ie: it couldn't hold many branches) for a lot of them as the branches would need more space.
What about grapes, hothouse tomatoes, mushrooms, and other environments like those where there are smaller lugs of material that people are picking into and have to transport back to central depots? Any thoughts on potential pain in moving materials there? (settings such as this: View attachment 498066)
I suspect that it would work, but I would ask someone in one of those fields.
Aaron Z
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #26
I just drove by miles and miles of grape and apple orchards this weekend in SW lower Michigan. They have been pruning heavily. All of the prunings are on the ground between the rows. They'll come back and pick them up mechanically. They prune. Then move them to row. They pick up mechanically. No one stands there and picks up the prunings by hand.
Heck, I used to frequent a small orchard here. Neat OLD AS DIRT guy that ran it. It was probably 15 acres at most. Even he hired in a crew to prune in winter. He'd take care of mowing and spraying himself. Then he'd hire a crew to pick most of it, but he had a U-Pick that he ran himself. All he had was an old tractor or two to pull the sprayer and mow, and an old forklift to move empty bins in and full bins out of the orchard. That's it.
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #27
I would look seriously at Lawncare.
They have many guy running back and forth with wheel barrows full of mulch. Short distance, repetitive action, high cost/hr. If you could set up a FAST robot that could move mulch from a trailer to the current 'master spreader' you might really have something. It could turn a HUGE business opportunity throughout the US into your customer. An owner could purchase 4 bots running mulch and have only 2 guys working the job. Typically, there would be 3-4 guys all at $10-12/hr. Wouldn't take long to make that $4K pay for itself and then some in that instance.
They would have to be reliable and extremely durable. And NOT run over the homeowner's petunias.
The more I think about it... the more I like it in this instance. The market for 'grunt' manual labor in this instance is massive.
Dadnatron,
Thanks for the tip, I've posted several things to some of the more landscaping oriented forums with little to no response so we'll see (i.e. here: http://www.lawnsite.com/threads/robotic-following-cart-on-the-farm.464350/).
Our team is fabricating a more legitimate looking chassis and updating coding to get a more legitimate looking prototype up and running so perhaps in a few days/weeks with a better looking prototype we can get more interest.[video]www.agrbt.com/images/Chassis Build Day 3.mp4[/video]
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #29
I would look seriously at Lawncare. They have many guy running back and forth with wheel barrows full of mulch. Short distance, repetitive action, high cost/hr. If you could set up a FAST robot that could move mulch from a trailer to the current 'master spreader' you might really have something. It could turn a HUGE business opportunity throughout the US into your customer. An owner could purchase 4 bots running mulch and have only 2 guys working the job. Typically, there would be 3-4 guys all at $10-12/hr. Wouldn't take long to make that $4K pay for itself and then some in that instance. They would have to be reliable and extremely durable. And NOT run over the homeowner's petunias. The more I think about it... the more I like it in this instance. The market for 'grunt' manual labor in this instance is massive.
The serious lawn crews here are running a compact skid steers. At about 3 times the cost of this robot they seem far more useful. I can't see how these robots are going to significantly reduce human labor. Now the local Hardie's installed robot ordering machines and give you a discount for using them. I'm betting one compact skid steer and 2 men could WAY outpace the crew with 2 men and 4 robots. And the skid steer is useful for a lot of other task. I don't see how the robot wagon is going to do anything a powered wheel barrow or compact or full sized tractor/ skid steer can't do. With a capacity of only 250 pounds a manual wheel barrow is more comparable. I'd rather see a welder that I drag along the path I want welded and then it welds it. Or a CNC mill that I can quickly hit a couple of buttons and come out faster on one part than on a manual mill.
   / Robotic Following Cart to Replace Light Duty Tractor Tasks? #30
... There is no way we can compete with the overall capacity and capability of a $11K base price Powertrac PT425. ....
I've been thinking about this quite a bit pretty much all day off and on.... In all seriousness, if the $11K machine can outwork the $4500 machine 4:1 in the first trip, and make 10:1 trip ratio( I think it will be much higher than that), that's outworking it 40:1. If labor $$$ savings is the goal, put it to a spreadsheet. It doesn't pan out. You'd need many, many of those $4500 machines to keep up with one $11,000 machine (really $11,450 with the large light material bucket, plus shipping).
One person picking fruit as an example...
Let's say they can pick fruit and fill a cart sized container in 6 minutes. That's 10 containers per hour. They dump it in the box on the auto cart. It leaves to make the 1/4 mile round trip to the barn and back. The picker continues to pick while its gone. It comes back, he dumps his box on it, it takes off again, etc...
How fast does the auto cart travel? Lets say 3mph, as that's an average person's walking speed. There's 12 quarter miles in three miles, so it can make say 10 trips if you account for dump and load times. That works out well for our example, as the container on it is sized to keep up with one fruit picker person (if the distance averages out to 1/4 mile trips. Short distance works out better, longer distances, not so good).
As mentioned, it can only work for 5 miles. It'll be dead in 20 trips. That's about two hours of work. You'd need 4 auto carts to keep up with one person picking fruit for 8 hours, or 4 battery packs, or a quick charger that can charge it before the shift is over, etc... If you need 4, that's $18,000 for auto carts to keep up with one picker that gets paid only $300 per week working 40 hours for $7.50 an hour.
The picker could load crates in the field and deliver them to the barn himself much faster and cheaper with a tractor. Even if you had enough work to keep the picker busy for 4-5 weeks, that's only $1500 at most. Even if you had continuous crops and enough work to keep a guy busy all summer/fall, its not going to save enough labor to pay for itself because its small and slow.
And another thing to consider. Let's say the guy walks out from the barn to the first tree and the auto cart learns the route. It leaves and comes back to where? The guy has moved to another tree. He'll have to go and get it each time it comes back. That's the same distance spent walking as it would be to a crate set in the field every few trees. So no labor saving there at all.
Look, I'm being hyper critical of course. Just giving you some things to think about. I hope you can make a go of it. It sounds really interesting and poses a whole slew of problems to resolve. Keep working on it and keep updating us and good luck. :thumbsup:
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A57024)
Ditch Witch 6510A...
