Game Hoist
/ Game Hoist #1
FredH
Ruch , Oregon
N.H. TC-30
Several years ago , seen something similar to the picture below .
For the price they wanted , My Brother and Me decided to build our own .
Went to a local steel place that has a lot of recyled steel and purchased what We thought We needed . Some are rated at 300 pounds , while others are rated at 500 pounds . Based upon the size of their tube for 500 pounds , Ours is likely 1000 pounds or better . 2" x .25" wall round tube for main upright and vertical top . Vertical top is also supported by a brace of 4" x 1/2" flat bar , similar to the brace in the picture .
Started with a piece of 2" square tube that was a custom made hitch extension that was made for Me by a shop when I pulled my boat behind my camper . We added a piece of 1/2" plate to that at the end , to which We welded a 12" piece of 2.5" round tube that the 1st section of upright goes into . That 1st section , maybe 3' to 4' long , has a large piece of 1/2" plate welded to it for a electric winch . Then there is a coupler of 2.5" tube that the top section goes into .
The upright sections rotate 360 , thus once game is lifted it can be swung around to rear of vehicle for loading .
This past elk season , scored a 6 x 5 that hanging weight was almost 400 pounds without head and hide . Thus while hanging on the hoist while skinning , likely exceeded 500 pounds . Hoist No problem , H.F. winch , think it is the 2000 pound winch ??? , Well not so much . Got it almost all the way up , but had to manually lift / help it the last foot or so .
Yesterday , We decided to modify that hoist to make it easier to assemble . Lifting that top section up to drop it into the winch tube was a BI*** , with 3 of Us . Thus We ended up and cut the reciever extentsion , added a piece of 1 3/8" solid rod through out the entire length . Were We cut the extension tube , We welded a 7" x 1/2" round plate to the 1st section and also welded the solid rod to it . On the other piece of the extension , We welded another similar round plate , but did not weld the solid rod to that plate . 1 3/8" holes had been already drilled by My brother in the round plates , thus the rod is solid all the way through . In those round plates , the first has 2 holes , the second has 1 and the 2nd is also notched for 1/3 of the distance . Hard to explain , but the assembly , when installed in my hitch , will now rotate from vertical to a little past horizontal , thus eliminates having to " Lift " anything more than waist high . The 1st plate has those 2 holes , 1 hole for a pin to hold the hoist in a vertical position , the 2nd hole had a pin welded in place to act as a Stop , thus the reason for notching in the 2nd plate . When we lift it to vertical , it will not be able to go completly over the other side , as the second plate hits the stop .
I won't be able to get pictures till next week , but emailed my brother to go out to the shop to take a picture of Our " work " , so hopefully will add one later today .
Anyway , Now for a Question for You electrical and winch load smart ones . Truck is a 2006 dodge ram 2500 with a hemi , thus gas and single battery . I ran , I believe it is #4 gauge wire from the battery all the way to the rear of the truck , maybe say 15' for both wires . Connections at battery are large gauge , soldered connector's . Connection at back is one of these type :
From there it is also #4 guage to a small connector that I matched for the H.F. winch . Wire coming from winch is maybe 3' long , maybe 12 guage , maybe 10 ???
Winch never seem to " Overheat " just almost stopped near the top ( Like it was at capacity ?? ) . Truck was running the entire time , thus don't think that was a issue . Winch did not have entire cable out , looked like it was at 50% useable cable left . So Would I benefit from installing a second temp. battery in the bed to run the winch , with it being charged by the engine system . A bigger winch would likely be easiest ??? But will the current cable run it ???
We can build stuff , but winch loads , 12 volt electrical loads , etc.... puts me in Brain overload :)
Hopefully will add a picture shortly .
Fred H.
/ Game Hoist #2
He is the one I put together made from iron that was left over from the cultivated build. 2x2x1/4 sq. tube HD! 3/32 cable.20170204_104758_1.jpeg
/ Game Hoist #3
Here's a chart for 12V vs gauge and length of wire for amp draw. Not sure how accurate it is as it was found online.
If you are sure you ran 4 gauge wire 15' it should be good for a 150A - 200A load. Most of the smaller HF winches I've seen come with 6 Ga. wire. Even these small winches can draw well over 100A under load.
Mounting a battery in the bed to supply power to the winch is a good idea. It can be charged by the truck.
I prefer keeping the battery as close to the winch as possible for less line loss. Another chart I looked at says 15' of 4 ga. wire at 12V is only rated for 60 amps.
  • VIAIR_wiregauge_chart.pdf
/ Game Hoist
Kind of what I was thinking , since winch did not overheat but then when it slowed or stopped , we shut it off . Hate to buy a bigger winch and have it do the same , so thinking I will go with a remote battery setup that will charge from the engine system .
Here are a couple of pictures of just the base unit that slides into the reciever .
Dang thing weighs likely 40 or 50 pounds + , thus We have it the entire set up in components and now We will assemble in the horizontal position then rotate vertical either using the winch or winch and 1 of the many 27' 4000 pound ratchet straps that I have around here . I am the youngest at 57 , thus We be to old for to much manual labor . As they Say " Work Smarter , Not Harder " !!:thumbsup:
Jack : What do You think the capacity of yours is ? This was a average Elk that likely was over the 500 pound limit that the commercial ones are at . Since hanging is was right below 400 with out the head and hide which easily was 100+ pounds . Ours is likely overkill with size of tube , etc... , But Heck , what do they say , " Go Big or Go Home " :cool2:
Fred H.
Picture of 2 of My older Bro's . Been hunting with the one on the left since '77 :thumbsup:
/ Game Hoist #6
Add a pulley at your spreader bar where it attaches to the carcass, sounds like you have plenty of winch cable to make it work.
I would also add some fold down feet/legs so you aren't putting all that weight on your hitch.
/ Game Hoist #7
We are doing something similar for a deer lift/boat winch.Our thoughts are to put a deep cycle battery in the truck bed.Plan on charging as needed but not from the truck.I have a light duty hoist like pictured but plan on putting a leg to the ground.Tried it on the sidexside and it collapsed the suspension.Have an electric winch for the boat and plan on powering off the bed battery.
/ Game Hoist
In the second picture , the " Leg " off to the side that can be seen , is a piece of additional 2" reciever tube welded to a pad that will slip onto the 1 3/8 solid rod that extends out of hitch extension and also slips into the extension thus it makes for quite a brace or " Foot " on the back to hold the weight .
Just talked to My Bro and He agree's that a additional battery is a better option than a bigger winch at this point . Guess I will go that route and see if it works next season :confused3:
Fred H.
/ Game Hoist #9
By adding a pulley and routing the cable back to the frame you are doubling the capacity of the winch.
No need for a bigger winch.
/ Game Hoist
That can be Accomplished Real easily . Never even thought of that route . :thumbsup: Thank You :)
Fred H.
/ Game Hoist #11
Another option would be to remove the excess cable. Winches are rated with the first layer of cable on the drum. As the drum fills up, the diameter gets bigger and the pulling power is less.
If you only use the shortest length of cable needed, it should lift it.
/ Game Hoist #12
When you were describing the build my thoughts were, "this is going to take 2 men and a boy to get in place". I have one like in the first picture and it will hold way more than 300lbs. I hoisted a wild hog that was closer to 400 and it was work, but the frame didn't squeak. Sooner or later you MIGHT approach the limit of your truck receiver, so just be aware of that number as well.
Someone beat me to the recommendation of an extra pulley in the line. Just anchor it back at the top near the bottom of the last pulley and it will make it easier. I would weld a D ring or similar up there.
Those hoists are great for many uses.
I would try the extra pulley and some test weights before spending the cash for the wire. Doubling the capacity, will reduce the amp draw as well, so what you have might work out real well. One thing to remember, is it also reduces lift speed by 1/2. I would test it before removing any cable as well. Adding a pulley, doubles the amount of cable needed.
One other way to add support, something I have thought about, is movable and adjustable leg supports for the hoist frame. That takes a LOT of load off the receiver. I used to use mine for loading and unloading the 5th wheel sliding hitch from my truck. Lift it right up over the side of the bed and set it in place.
/ Game Hoist #13
Here's one I made last winter, put an offset hitch on the truck so I can still pull a trailer and let my tailgate down. I even made a stainless gambrel that adjust for large or small deer.
/ Game Hoist #14
Here is one of them not yet built, but in my head. This is a combined gaming hoist/ feeder filler like this model of game hoist 5 Best Deer Hoists of 218 – Hunting Fishing Plus - Hunting Fishing Plus Please excuse the poor Cad tool (Paint) and everything is sure not in proportion or even close to scale, but you get the idea. Also feel free to make any suggestions my way.
My feeders are quite high, and now I stand on the bed rail and closed tailgate and can barely get the sack over.
I have a turn over gooseneck hitch so, so I decided to drop the ladder end into it to help stabilize it. Then pin it where it meets the platform.
Here is the rear view, and I have two vertical parts with my legs down to add extra stability.
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2020 ASV RT65 (A60462)
Unverferth Assist Wheels (A64127)
Unverferth Assist...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
