Deere MX7
/ Deere MX7 #2
Matt, my only thought on using the 7' cutter on your 110 is the startup wear on your PTO clutch. Those are some big blades to get spinning...
Slowing your ground speed in heavy cutting is something you can control. Gettin' those blades up to speed isn't.
Still have my 110. Just finished clearing and burning another 3 acres this fall. Great machine!
/ Deere MX7 #3
Nice to hear from you, been a while maybe a year or two?
Sounds like you are getting along with your place.:thumbsup:
/ Deere MX7 #4
It has been a spell... Yeah, we're still spending money here - I've been told that's a manner of "getting along"..
Piddling along with around 30 acres of hay these days. Could do more acres but the wife wants to play more in the summer and work less on putting up hay. Went to a round baler this last year and dropped time spent in the field baling (handling; loading/unloading, etc.) by half at least!
More time in the gardens, greenhouse, and high tunnel, though. (I'd rather bale hay....)
Anyways, hope all is well with you. You ever buy that "big" tractor?
/ Deere MX7 #5
Good Lord it's great to hear from you AK! I didn't want to bug you after your horse accident... but I hoped that you hadn't 'fallen off the twig' either. :)
/ Deere MX7 #6
I would not be worried about the weight, but as stated i would be WORRIED about the pto wear at start up, and CONCERNED about the gear box issues. I assume you saw that the repair kit changed to ratio to a higher speed, so that would stress everything that much more. I would consider MAYBE getting it if you went down a blade size to 6ft total cutting length. unless you need to get that close to something, I see no harm in doing that, i would only cost a set of blades, or maybe even just shortening the existing blades. Let us know, but that's my 2pennies.
/ Deere MX7 #7
Nah.. Still jumpin' and runnin' and ridin'... Thanks. That Army surgeon fixed me up really well, actually. No lingering problems at all. I am FLAT-OUT grateful!!!
Life is good.
/ Deere MX7 #8
Have not bought a larger tractor yet, spent money on laser machine control automatics instead. Will see if work picks up enough to warrant a larger tractor.
Also building a greenhouse for produce production with geothermal piping too. Will have a better handle on this next winter. My lawn area is totally dug up right now and need to get this fixed up this spring. A lot of playing in the dirt with this but still kicking.
/ Deere MX7 #9
I'm gonna try to not appear to be simple-minded...but, is that laser system like the setup you see on finish graders doing the final "trim work" on a roadbed just before paving? Looks like a transmitter/receiver mounted on the moldboard blade and appears to communicate with a fixed transit - surveyor device?
Pretty "high tech"!
Geo-thermal greenhouse... Whoa. That would be impressive! (I don't want my wife to even HEAR the words geo-thermal!)
She's been on my butt to run power and water to HER high-tunnel for couple of years, now. Putting it off cause I'd have to trench a 9' deep cut approx 500' along the edge of my best hay field. Be 3 years later to recover some of my production along that strip. Aargh.
/ Deere MX7 #10
Pretty "high tech"!
Pretty much, except I am building this with dual receivers one on each side of the blade. Hope to have this all ready to work for March.
The green house is only 2000 square feet and has 2000 linear feet of 4" corrugated pipe buried 9' deep. There are 20 runs of 100 ft. tubing which are connected to 12" pvc pipe manifolds. If this works out well I plan to build on a larger scale, if not I have plenty of room for a nice garden.
/ Deere MX7 #11
Had a thought, when (not if, I am married too) you go ahead.. could perhaps run the trencher one way shallow, to take out the topsoil, and go back the other way to full depth.. then you can backfill the trench and put the topsoil at the top? Our neighbours put all their waterlines in during a dairy conversion and although it was way more work, the waterlines were easy to find in the summer. The only part of the field that grew grass. Kinda like deep digging a garden I guess. Sounds really interesting stuff
/ Deere MX7 #12
I don't know the weight differences between a MX7 & JD 709 but my 709 @ 1145#s let my JD 2040 & now my Kubota M7040(64 pto hp) know it's back there when I raise it up. One must remember a 7 ft cutter hangs waayy baack behind tractor
/ Deere MX7 #13
Jim, good to see you're still on the air.
Yup... It's a big ol' slab hangin' back there! IIRC - the 09 model is the HD unit and the MX is MD. Probably within 150 lbs of each other, though.
I'd guess that his 110TLB will weigh more than the 2040 as well. The 110 will run it.. Might not like it!
/ Deere MX7 #14
AKfish
Yep I'm still hangin in here. I sent you a PM when I 1st noticed you had started posting again but I guess it's in cyberspace. It's nice to see you back.
Jim
/ Deere MX7
AK, I was wondering where you were hiding as well. I actually went with a semi mount bush hog 3008. I really had reservations about the MX7 shaft failure and after talked with my dealer about the two. His advice was the semi mount and twin spindle unit would be a less where and tear in the 110. I'm mulling the idea of getting a Deere demo 5083E at the dealer, so I feel the 5083E will be a good match for the Bush Hog.
Matt
/ Deere MX7 #16
Hey Matt, you probably saved yourself some $$$ and headaches over the long haul with the 8' twin spindle - IMO.
I fell into a similar spot a couple seasons ago. One of my dirt guys had a low acre MX-8 that he bought to use with a DOT-highway roadside brush clearing contract. Discovered that his 2wd 100hp tractor was a "boat anchor" in the steep shoulder road ditches! Stuck all the time. Track Bobcat with front mower was a better tool.
I've got a low-hour cab 4720 with all the bells and whistles that I'd love to trade on a low-hour cab 5083E or 5100E. Either of those tractor's are rarer than "hen's teeth" up here. Never seen one anywhere in this country!
/ Deere MX7
I really wish I could compare an E and M side by side but they aren't common at dealers in this area. It's mostly CUTS, and they 5000 series are mostly ordered. I'm a little gun shy on an E because of the issues posted a lot seemed to have. It looks to me like it's mostly on the India made 5000 series which I believe ends at the 5065E? I'm also not sure if I want open station or Cab and I figure it'll be in the woods with it a lot so the cab is iffy for me. My other plans with it would be mostly ground engagement and Hogging so I may look for one without a loader and then later on add one if needed. Why isn't the 4720 working out for you?
Matt
/ Deere MX7 #18
Matt
Yeah, IIRC the5083, 101, 85, 100 are assembled in the US. Routine work in the woods is a bad combo for a cab tractor -IMO.
The 4720 Is a great chore tractor - quick, nimble in cramped spaces, lot's of power (not enough traction). Loader capacity for the 400CX is on a par with the 110TLB (not as heavy duty, though).
I like it for snow work around the place, manure work, putting in fence posts, etc. But, I'm gonna scale back on the number of square bales and do more rounds. And, I think using the small square 10-bale grapple on the tractor as well as handling round bales full-time would be more wear and tear on a smaller tractor than is sensible.
So, I'm probably gonna keep my eyes open for another 5000 or maybe a small-frame 6000 machine. Some initial homework tells me a 6330, 6430 is a better deal than a 5100-115M.
/ Deere MX7 #19
GreatWhite Hunter, you'll get the loader cheaper with the initial sale, just a thought.
AKfish, i'm waiting to see what the new 5r series tractors are going to offer, with the r series being the "cat's meow" in the Deere lineup.
Ronnie
/ Deere MX7 #20
Ronnie
I would like to see Deere come out with a 5r series with multiple range hydro transmission.
2018 Ford F-250 Ext. Cab Pickup Truck (A66736)
2018 Ford F-250...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2016 Dodge Grand Caravan Van (A66738)
2016 Dodge Grand...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
