Blades on a box blade
Status
Not open for further replies.
/ Blades on a box blade #1
Catman8
Gold Member
California
Massey Ferguson 30B, John Deere 2032R
Hello TBN members, need some advice. Owners of box blades: How straight, flat, or parallel do you expect your blades to be. I bought a new box blade and when I bolted the blades to the box they have a curve to them along the length, if I was to hold a level on the bottom of the blade it is not flat. Is this anything to be concerned about or do the blades get ground flat when you use then. I have no experience with box blades so you input is appreciated.
/ Blades on a box blade #2
I think you could get help if you post some pictures of this situation. For me, its a little difficult to picture what you are describing.
Ok, thank you. When it's light out tomorrow I'll take a pic.
/ Blades on a box blade #4
A guess, with no photos to look at:
If the blades bolt to an angle iron, like this but inverted )V( I suspect the angle may be curved due to warping when welded. This would make straight blades curve when mounted.
Bruce
/ Blades on a box blade #5
It certainly isn't going to help! They should be straight. Without pics my SWAG is to return it for something that is a little higher quality.
/ Blades on a box blade #6
Good advice right there.
Bruce
Really busy today and did not have time to take photos, but you have described the problem, when I lay a straight edge on the V portion it is not flat, so when you bolt the blades down tight it flexes the blades and you no longer have a straight blade. Question I have for you all, did you check your box blade to see if the blade was flat or are you just assuming it is. My opinion is that it should be dead flat since you're using it for grading purposes, but I don't know what the industry standard is.
/ Blades on a box blade #8
Are you sure your bucket is flat?
Edit for brain fart:ashamed:
Sorry I meant the heavy angle iron mounting on the box blade. Is it flat or bowed in the middle? A good straight edge should determine whether the grader blade or the box blade is the problem. If the box blade mounting is straight you should be able to pull the blade straight with the mounting plow bolts. If the box blade mounting is bowed slightly you may try shimming between the blade and mounting. Otherwise I would just use it as is.
/ Blades on a box blade #9
My bucket and box are flat! Wouldn't want or have it any other way.
/ Blades on a box blade #11
Are you worried that your road 9or what ever) is not going to be flat after you do work to it? When you say blades are you talking a land plane (which normally have two blades) or a box blade with a single blade? The only thing I would be concerned with would be the bottom of the blade, the part that actually touches the ground, the part with the holes for the bolts wouldn't bother me one bit if it wasn't flat. Even then I wouldn't worry about the edge not being too flat. Even an inch (which I would think would be pretty extreme) probably wouldn't be noticeable in the dirt over 5 or 6 foot wide blade. I guess that's the real question for you, just how much is it curved?
My box blade does have two blades, one on both sides of the inverted V, because the V is not flat along the length it bends the blade and that results in the edge that touches the ground not to be flat, I have not measured it yet but I'm guessing 1/8" to 1/4" in 60". I figured I would get varying opinions on what exceptable is. I'm not trying to be ****, I just think it should be flat so each pass does not have a dish to it.
/ Blades on a box blade #13
1/8 - 1/4" would drive me nuts- especially if I was doing finish/final grading.
/ Blades on a box blade #14
...I bought a new box blade and when I bolted the blades to the box they have a curve to them along the length....
This would not be acceptable, I would return it and see if another one was better made. What brand is this???
/ Blades on a box blade #15
1/8" flex over a 5 foot blade? Come on guys, this is not a big concern. The blade will wear more that that with minimal use.
I really don't want to mention the brand, unfortunately when you mention a brand you get accused of brand bashing and unfortunately the point and subject matter of a thread gets way off subject, at this point I am more interested in other's opinions and what the standard is and what we should expect from a quality built box blade. Not ignoring your question but I think you know my point.
I'm just curious, at what point would you reject a box blade being not flat on the cutting edge, over 60" 1/8"-1/4"-1/2" ? I'm just trying to get some idea of unexceptable. If you had a blade that was not flat do you think it would wear flat Or continue to wear curved.
/ Blades on a box blade #19
Catman, how about a pic of the box blade and the cutting edge?
Jim
Jim
If you read post #17 I really don't want to take a picture because it might give away the brand, and I don't want to be accused of brand bashing or get a lot of people mad, maybe I can try to take a picture without giving away the brand. I have no experiance with box blades and want others opinions who are experienced.
Status
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
