Good morning!!!!
   / Good morning!!!! #54,491
Kyle. Metal is the way to go. Standing seam is better than D-rib. But D-rib is better than shingles.
We always put double bubble insulation under metal. Stops the sweating and helps deaden the sound. Although I don't remember ever being bothered by rain sounds in an insulated home.
The house I grew up in had the green metal roof. Never noticed it heating up the house. And didn't notice the fade until you placed a new piece next to it.
   / Good morning!!!! #54,493
Insurance adjuster is going to help us replace the roof. Thank God. I want to upgrade to metal. Asking for advice from you wisemen. Galvalume has 20 year warranty but painted has 40 year. Shiny would look best but shine wears off after a few years. White would be best choice to lower attic temp, but forrest green would look better. I plan to blow in more insulation while some of the deck is off. Anyone have a dark colored metal roof in a hot climate? Would that be stupid? Would green last as long as white?
2 of my 4 building have metal roofs. One is almost 80 years old. In the 45 years I have lived there I have painted it twice. Silver both times. I am going to paint the other building with metal this year after 30 years. It will be done in silver. I want to do the other 2 buildings with metal in a few years Will be done like Don's.
   / Good morning!!!! #54,494
Calcium. To fix high parathyroid hormones and very low Calcium levels. May help with speech problems.
Calcium is one of the things they check for during a regular blood test. How long has it been low?
   / Good morning!!!! #54,495
Good evening all. 32F the last 2 mornings, mostly clear skies, and near calm winds. Friday afternoon was breezy with a 50F high, today was 55 and less breezy. Friday stress test went well, staff was happy with data collected. Nurse did remark that heat rate dropped from 145 bpm to 105 by the time the "working" echo cardio-gram was done, about 2 minutes and was impressed. Cardio-gram was to base line the murmur. Rode the 10-speed yesterday and today, yesterday adjusted bottom bracket after ride, all good after today's ride.
   / Good morning!!!! #54,496
Don, thanks for the reminder will work on hydration!
Buckeye, how did you get that to follow you home?
Welcome back Larro!
   / Good morning!!!! #54,497
Welcome back Larro!
A check with some big numbers on it helped. Took it for a short spin around the property.
Then got the tractor out and cleaned up a lot of the limbs I trimmed last week. It's been 11 yrs since I cleaned out the woods on the other side of my creek. Found a corner pin, used to have a pvc pole next to it, but it's gone. Went to where I thought it should be, moved some downed branches and kicked back some leaves and there was the pin. Got a lot of downed trees needs cleaned up. Used to Bush hog that side, but haven't in a few yrs. Briers really starting to take over.
   / Good morning!!!! #54,498
Blood test did not show low Calcium. Only high thyroid hormones blood test that is not a normal test. Plus 24 hour urine test. Which is not a normal test.
   / Good morning!!!! #54,499
28 going to 49 with a bit of snow tonight.
Eric, hope you having a grand time with your grandson. If he lives in town, I'm sure the open pastures and sheep are a treat.
Buckeye, nice looking vehicle. I'll ride by the local dealership again today to see if anything follows me home...so far no luck...did you wear gasoline as after shave or any other trick?
   / Good morning!!!! #54,500
2017-01-29, 0627
30 right now...low 30's is the forecast high...maybe some snow showers today too.
No plans...just putter about.
2014 Aerway Aerator (A55973)
2014 Aerway...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
Fork and Frame Skid Steer Attachment (A56857)
Fork and Frame...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
202482 (A54757)
202482 (A54757)
