Hydraulic Fluid type?
/ Hydraulic Fluid type? #1
nike
Ontraio
Belarus 255
I have a Belaruse 250 AS tractor. The manual instructs you to use Diesel in the hydraulic system as fluid.
1989 Tractor. Desiged for extreme climates. I was thinking that a different fluid should be used.
Does anyone have a suggestion?
/ Hydraulic Fluid type? #2
Un-informed response... why not just use regular hydraulic oil? I'd guess better lubrication, less foaming, and probably other advantages I don't know about??
/ Hydraulic Fluid type? #3
"Diesel" is Russian for 30wt non detergent motor oil- or so I'm told
/ Hydraulic Fluid type? #4
Automatic transmission fluid works fine as hydraulic oil. It's thin, so works fine in the cold. Has a lot more lubrication than diesel fuel I would think. I use Dexron 3 in my tractor.
Seems like any low viscosity hydraulic oil would be a good replacement for you.
Thanks I will try Dexron 3. I am replacing the pump and flushing the system.
/ Hydraulic Fluid type? #7
My comment wasn't a joke- everything I read online said the machine takes 30wt
/ Hydraulic Fluid type? #8
My tractor uses 40W motor oil for hydraulic fluid. Its an entirely hydraulic machine. Just a motor turning 3 hydraulic pumps (one variable volume pump for directional control, one for the hydraulic PTO and one for the FEL/Steering circuits), all fed out of one common 10 gallon reservoir filled with 40W. I've been adding 5W40 Mobile 1 at every 50 hr filter change for 16 years, so it's partly that as well, now. Works fine.
I have not been able to get out and work on it, thank Goodness the snow has held off. I need the hydraulics working for the snow blower.
I will use dextron . 30 wt sounds great for the summer time but with the cold i think dextron would be better.
Thanks again for all the help.
/ Hydraulic Fluid type? #10
Normal motor oil has detergents in it to pick up crap & keep it suspended in the oil. Great when you change the oil once or twice a year. Not so good for long change times & systems that should be cleaner. Non detergent oils let crap fall out of suspension into the bottom of the sump. I wouldn't use motor oil on my non motor equipment. I do use non-detergent motor oil in my compressor though & would use it in a splitter or dump trailer hydraulic system.
/ Hydraulic Fluid type? #11
Great point! Non detergent is the recommendation in this application and others (Komatsu etc) that use straight weight oil.
It will be interesting to see how ATF works in this application. It's the general consensus the tolerances are greater in these machines which is one of the reasons for straight weight oil. Maybe OP is a place colder than Russia which would require the low weight ATF.
I have finished installing the new hydraulic pump and have filled the system with Dextron3.
The hydraulics work great even with an outside temperature of -23c . That -9.4 F.
Thanks for all the help.
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
