Smokin' deal on 10,000watt generator $649 (Today only)
   / Smokin' deal on 10,000watt generator $649 (Today only) #121
I don't know if you have propane for the house supply or not... but if you do, you might consider what I did last year:
I had the LPG supplier tie into the propane line coming into the house and add an outlet with correct fittings so I could simply run my $649 generator right off of my main 250 gallon LPG tank. I also keep 6 of the smaller 20# bottles - just in case. The supply line from my main tank installed was about $100.
I have to try that Gem99ultra,
I ran my 10k generator a couple hours yesterday and got to thinking about your post on hooking the generator to my 500# LP tank. Right now I have the tank 60' away from the house. It has a high pressure regulator on the tank. That goes then to a small copper line to the house with another regulator at the house. From there it goes to the furnace etc.
Between the high pressure regulator and the low pressure regulator on the house I teed of another line to a regulator to run my grill.
I am trying to figure out how to hook my generator up to work on the big tank.
I could run a high pressure line from before the first regulator and bury it 75' to where I would set the generator. Then I could use the pigtail on the generator just like I would on a small 20# tank, I think. I hesitate to do that because it is on a hill with all rocks.
The other option would be to hook the generator up the low pressure line after the last regulator just before my grill. My confusion would be where to hook it on the generator. I'm doubt hooking the low pressure line to the high pressure pigtail on the generator would work.
I am not sure if hooking it between the regulator on the generator and the motor would work because there are two lines there for some reason.
I was just wandering how you got yours piped up. It is a good idea though.
   / Smokin' deal on 10,000watt generator $649 (Today only) #122
My setup seems to be exactly like yours, i.e. high presure regulator at the tank, copper line to the house to another regulator. The LPG tech needed to T off of the house supply regulator to a low pressure regulator for the generator. I think he set the generator regulator at 12 pounds. Here's a picture of how mine is rigged:
The cross pipe in back of the new regulator is for a brace only and has no other purpose. Also as an aside, I asked the LPG deliver guy last December if this setup was possible. They said sure, but advised me to place my request in April or May after the winter rush passed and they were sitting around looking for something to do. Otherwise, the price would have be higher.
With this setup I have a heavy duty 6 ga extension cord to run to my water pumps and transfer box.
So far I've only used propane in my generator. I hope to be able to continue with that system, but I do have a gasoline supply just in case.
   / Smokin' deal on 10,000watt generator $649 (Today only) #123
Would be so kind as to show or explain how it was connected to the generator when it does happen? I have the regulator like yours for my grill I want to tap off of but the final hook-up is a concern.
   / Smokin' deal on 10,000watt generator $649 (Today only) #124
I don't have my generator out by the connection right now, but in the interim, the black regulator on the right has the same connector fitting as the propane bottles. It has a dust cap on it right now just to keep it clean, but it's the same fitting that the bottles have. The generator just plugs right into that line same as with a bottle of LPG via a little pigtail that came with the generator.
I did buy a 15' LPG extension hose from HF that could also be used if I didn't want to sit the generator that close to the house. The hose was bought primarily for my weed burner, but it's plenty large for the generator.
   / Smokin' deal on 10,000watt generator $649 (Today only) #126
Late day 4. Linemen replaced our transformer and the power is back on! Generator ran for over 15 hours without a hitch today. Will use it this weekend until it runs out of gas. Once gas is used up will run on propane for a while to clean out the carburetor, then I'll change oil before putting it back in the shed. Total run time was about 40 hours for this storm. At first I was constantly using my Kill-A-Watt meter and my multimeter checking voltage and Hz but then I got to where I just checked it after starting. Something I have said I was going to do and never did was find an 80-200 gallon Propane tank to run this generator. That's been bumped up on my to do list. Have a couple 5 gallon tanks but it was faster to fill gas cans than take those little bottles to get filled or exchanged. I want a propane tank large enough to run the generator a few days but small enough that if the Coop can't get out here to fill it I can load up in the back of my pickup and take it to be filled. With the price of propane at the Coop now it would have cost me half as much to run the generator this week if I'd had a large propane tank.
When I changed oil last time, it was about 40 deg. and the genrator was suspended from my loader bucket. When oil started flowing out the fill tube I rocked the generator back and forth. A large air bubble came out the tube. So I'm thinking trapped air maybe stopping the crank case from filling all the way. That's why after first fill I'm going to start the engine then recheck the oil level.
What kind of Hz reading were you getting?
   / Smokin' deal on 10,000watt generator $649 (Today only) #127
I tested outlets on every 120v breaker in the house and it always read 62Hz. My Kill-A-Watt meter is supposed to have a Hz accuracy of 2%.
   / Smokin' deal on 10,000watt generator $649 (Today only) #128
   / Smokin' deal on 10,000watt generator $649 (Today only) #129
Found a YouTube video on how to get the DuroMax 10,000w generators ready for storage after they have been ran on gas. I did not realize about a half a cup of gas is left in the carburetor even after running the engine till the tank is empty.
View attachment 497893 View attachment 497894
youtube.com - PoweredBy DuroMax - DuroMax 10000EH How To Winterize Your Generator
That is a common issue - part of why I've gone to just stabilizing the gasoline, tank full, in things that won't sit longer than 1 year.
If you can reliably drain all the fuel, that will work - but in my case I want my generators to start ASAP (no stumbling around in the dark fueling), and extra steps/carb mods re. draining don't appeal to my lazy side.
Rgds, D.
   / Smokin' deal on 10,000watt generator $649 (Today only) #130
i live way out of town and i put gas stabilizer in all my gas cans, lawn mower, weed eaters and leaf blowers, 4 generators, side by side, tractor, backhoe, and chainsaw. both 2 and 4 cycle all but cars. some of my equipment has sat for multiple years cause of my stroke and broken ankle. also when my house was a summer house, it might sit for a few years. never had a problem with any equipment. even boats that the outboards and inboards sat for years. stabil all gas cans year round so equipment is all ready year round. can't emphasie enough!!!!
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
UNUSED FUTURE SKID STEER QUICK ATTACH SWEEPER (A51244)
UNUSED FUTURE SKID...
2024 John Deere 872GP Articulated Motor Grader (A52143)
2024 John Deere...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
UNUSED AGT QUICK ATTACH FLAIL MOWER (A51244)
UNUSED AGT QUICK...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
