/ Harbor Freight Tools that don't suck #6,803
Finally got my 1/2" Earthquake XT air gun that has been on backorder since beginning of November 2016
And? How does it look ad feel? Fit and finish? Comments? Use it yet?
/ Harbor Freight Tools that don't suck #6,805
I haven't had any issues with Harbor Freight tools yet. But I am just a weekend DIY Mechanic that use the tools 1-2x a month and I'd like to think I'm not too hard on them. I had 1 tool break once, it was a clamp. But i was able to exchange it at the store without any questions asked and I've been using this one now for about 3 years with no issues!
/ Harbor Freight Tools that don't suck #6,806
HF is good that way for some tools where it's hard to make the investment in a little used tool.
/ Harbor Freight Tools that don't suck #6,807
Okay here is a HF tool that kinda doesn't suck. I just bought an easy out (screw extractor) set. Very first use, I shattered two drill bits in seconds. Reverted to my non HF bits and drilled the pilot holes. The HF extractor worked perfectly though to back out two 5/16-18 screws in the vice I am restoring.
/ Harbor Freight Tools that don't suck #6,809
Last time I used an easy out, the easy out broke off. My next easy out was to pay someone to remove the bolt.
/ Harbor Freight Tools that don't suck #6,810
I don't think I've ever used an easy out that didn't break. I suspect the reason is that I rarely use a drill press to drill out the stuck bolt and doing the drilling by hand just puts too much stress on the bit.
The last time I broke my easy out I ended up using a special small chisel to back the broken bolt out. I was impressed how well it worked compared to the easy out.
/ Harbor Freight Tools that don't suck #6,811
I've had pretty good luck with screw extractors. I'm no expert but I the key is to get a hole drilled in the crapped up screw as big as possible and use the largest extractor. Of course you don't want to go too wide and break the walls out that you're trying to grip. The easy outs I have used don't break but sometime they twist a bit if not large enough diameter for the torque applied.
/ Harbor Freight Tools that don't suck #6,812
I've got that same set. I agree, the bits suck. I broke one first use, too. :laughing:
/ Harbor Freight Tools that don't suck #6,813
Maybe it's just me but HF needs to put some new and different items in it's coupon and sale fliers. Time to shuffle things up so it's not the same old predictable items time after time. But maybe it's just me.
/ Harbor Freight Tools that don't suck #6,814
That would be nice but remember they buy by the boat load and have quite the distribution and marketing machine allowing to move through their inventory. Adding a new item to their repertoire is probably more trouble and risk than it may seem. They have it wired for sure.
Yea, especially the free items. What's a guy to do with 50 flashlights? :laughing:
/ Harbor Freight Tools that don't suck #6,816
/ Harbor Freight Tools that don't suck #6,818
Getting the hole drilled in the center of the bolt is very important.
/ Harbor Freight Tools that don't suck #6,819
Agree.
Center punch the h*** out of it. You might have to grind the stub flat to do this. And be sure to use a left-handed drill bit.
For my last project like this I bought a premium drill bit and ez-out from an industrial-supply place. For most projects HF tools are 'good enough' but this was a broken stud in an engine front cover where botching the job would cost hundreds to remedy. With good tools everything went according to plan. Here's a post I made describing the project including a photo. That wasn't supposed to break.
/ Harbor Freight Tools that don't suck #6,820
Ok so I found a website that claims the coupons they have are legit. And that I can get a bunch of cheap stuff for free with no additional purchase required? True statement?
Yes I realize the flashlight and multi meter will be junky but likely good to keep in the tractor tool box for emergency.
2012 John Deere 6170R (A57148)
2012 John Deere...
2019 CATERPILLAR 272D3 SKID STEER (A62129)
2019 CATERPILLAR...
2025 CTRA 4X2 T/A 16FT ENCLOSED TRAILER (A59906)
2025 CTRA 4X2 T/A...
2017 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2017 Chevrolet...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A60352)
2013 Chevrolet...
