Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #4,342
Yes. The dry kind. I don't think the species make a huge difference.
You can also make biochar in your stove by putting wood in a box inside your stove. A section of stove pipe and a couple of caps works well. Similar to this.
Biocharlie Biochar Log - Make Your Own Biochar in a Fireplace - Blue Sky Biochar
You could also dig a trench or pit in your yard to improve yield
Ideally having the same sized material works best for making biochar but you can just push the bigger pieces to the top or simply pull them aside and let them burn out while you quench the main pile of biochar. Here is some information I used when I was getting started.
Backyard Biochar: Top Lit Open Burn
Piles like this are pretty easy to manage by hand and a hose could be used to quench.
I'll check out that video later. We have some pretty crazy burn laws here. Last year we had a burn ban because of air quality:rolleyes:
I was have an EPA stove and after it up and burning I shut the draft all the way down and it burns a secondary fire. After the wood is burned up there is a big pile of coals. I could leave the draft closed all the way down (instead of opening it up for them to burn down and stirring them) and I would have biochar.
/ Tractors and wood! Show your pics #4,343
Headed to the mill after coffee. A little more on than I like but I wanted to clean up the landing before this next batch of warm weather.
gg
/ Tractors and wood! Show your pics #4,344
/ Tractors and wood! Show your pics #4,345
gg
About how much money does that load bring if you don't mind sharing? Just curious.
/ Tractors and wood! Show your pics #4,347
Well by my measurements it scaled 640 Board Feet. I am usually pretty close. The mill pays $300/MBF (per thousand BF) for spruce/fir saw logs so if there are no culls or down grades to pallet wood in the load I should get $192. Don't ask how much I make an hour - I would have to lie to stay out of jail. :D It is less than minimum wage.
gg
/ Tractors and wood! Show your pics #4,348
Hi all. 70 degrees here just SW of Abilene TX.
Wife just texted me from home in Oklahoma. Says the squirrels are a lot happier since I cleared the hillside with the Kubota and made the yard larger.
"They can now make faster time from the bird feeder on the deck to the deer feeder at the edge of yard without all those obstacles that was in the way!
/ Tractors and wood! Show your pics #4,349
Whoops, wrong thread. Meant to be in the good morning thread. Sorry bout that!
/ Tractors and wood! Show your pics #4,350
gg
I was going to take swag and say about $200 but didn't pay attention to the type of wood. I'm sure if you delivered black walnut it would be quite a bit higher? Whatever kind of wood that is, we don't have it here.
CFG Industrial H12R (A60463)
CFG Industrial...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2014 FREIGHTLINER  CASCADIA (A60736)
2014 FREIGHTLINER...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
iDrive TDS-2010H...
