fitterski
Gold Member
- Joined
- Oct 20, 2016
- Messages
- 377
- Location
- Nouvelle, QC
- Tractor
- 1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
You still need a res.... CJ
Looks like maybe a 10 cu-in pump will be my upper limit & maybe 150 gpm max. That 'small' reservoir would then still need around 30 gallons i.e. almost a full size drum! Do you mean radial piston units or axial? I would run them only a fraction of the time so those durability specs would be more than adequate.
The more I get into it the more problematic it becomes. 300 lbs each pump & motor & reservoir is 900 lbs. An Allison 6-speed automatic can do all of that and more at 350 lbs. The mechanical solution does open other issues of course
