XR3135HC ordered
/ XR3135HC ordered #1
cford36
Gold Member
Western, NY
LS3135HC
Well finally pulled the trigger on a XR3135HC. Loaded tires, radio and adding bucket hooks. Also will be getting a Puma 64 snowblower which they are converting to be loader mounted. Will post some pictures when it comes in.
Thanks for all the info that is posted here. This has been a 2 year project.
/ XR3135HC ordered #3
Congrats on ordering your new tractor.
I believe your tractor is 66" wide.
Won't the puma 64 be a little narrow?
Is the dealer going to add wings to the blower?
How is the dealer converting a 3 pt blower to front mount?
Please let us know.
/ XR3135HC ordered
Please let us know.
I really tossed the size of the blower around for a long time. The dealer has been putting Lynx 62 blowers on the front of these with good results. I wanted something wider and was going to get the Lynx 70. At the last minute I decided I really wanted the little extra durability of the Puma so I sacrificed a few inces to get it.
The dealer is taking off the 3-pt mounts and putting on a quick attach plate, along with a hyd motor on the blower. Putting an aux hyd tank on the 3-pt hitch and a rear PTO driven pump. He will run all the hoses under the tractor, including lines for the hydraulic chute and deflector.
Here are pictures I took last year of a blower they had sitting there. Its missing the hyd cylinder for the chute, but you can see how they convert the mount. This was a Lynx.
/ XR3135HC ordered #5
Congrats, cford36! We are quite pleased with our 3135 so far.
/ XR3135HC ordered #6
Pronovost makes some nice strong stuff up in Canada. They also used to make back hoes. I have one of there's mine is a Hardy, Pronovost bought out Hardy some years ago. They then labeled the back hoes under the Puma name, but it appears they have stopped making them and loaders.
/ XR3135HC ordered
Here are pics of the blower they converted.
/ XR3135HC ordered
Looks like LS added a lever to move the 3pt from outside.
/ XR3135HC ordered #13
Very nice. Mine doesn't have the handle in the back for the 3pt. That's another extra feature you don't usually see on tractor this size.
I like the idea of the loader mounted blower. I've seen pictures of another brand that had the tank mounted on the blower so you could still use the 3pt for a rear blade. I priced the factory 63" front mount blower when I bought the tractor and it was something like $6k with the mid pto kit.
I had a front mount blower on the last tractor but it was a pain swapping from that to the loader whenever I needed firewood.
How easy is this setup to remove? I wonder if they ever put couplers for all the hoses up front?
Jay
/ XR3135HC ordered
Jay
I think the 3pt handle is a recent change.
The dealer converted the blower from a 3pt mount. I guess it would be possible to put the tank where you want it. The conversion was $4000 on top of the blower price.
In regards to couplers, not at the moment. I guess I should have been more specific on that. I just assumed there would be. I did mention it and they said they have looked into doing it but they would need to use high flow couplers to maintain the proper flow. I will be looking into getting some. Shouldn't be a big issue. I definitely want to be able to easily change blower to bucket.
My last tractor had the mid PTO to a front mount. I really wanted to stay away from that if I could. They are expensive and I found to be a pain to change over.
/ XR3135HC ordered
JL,
Does yours have the parking brake warning horn? Not sure if they are on the 3037 or yours. I know others with other brands have complained about not having one.
/ XR3135HC ordered #16
JL,
My 3037 parking brake has a dash light. It beeps if I get off the seat or I shut it off without applying it. Also beeps if I try moving the tractor with it on. Its a constant reminder to either apply or release the brake.
/ XR3135HC ordered #17
Awesome! Congrats on the new tractor.
I really like that outside 3PH control. May have to look into that.
Regarding the parking brake warning, our 3135 is like George's 3037; dash light and beeps.
/ XR3135HC ordered #18
It looks like in order to remove it you would have to undo the hydraulic connections to take it off. The lines go over you axle. With quick disconnections is the way to go.
/ XR3135HC ordered
This will be the first change.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
John Deere 9550 (A64126)
John Deere 9550...
213063 (A64276)
213063 (A64276)
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
Unverferth Perfecta 3pt 20' Field Ciltivator (A64126)
Unverferth...
