Wood Splitter advice
   / Wood Splitter advice #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I've been reading and watching a lot about wood splitters here on TBN and YT. I have always had a bit of firewood around and would use a wood stove while on vacations. However, my move to a cooler climate has me looking at wood as a "required" task instead of a novelty. I went to a box store and purchased maul and have been enjoying splitting by hand. I've also been looking at splitters including the electric flywheel type, hydraulic 3 point models and the traditional hydraulic with small engine models. I could also rent one once or twice a year.
I'm in north Idaho with mostly pine, cedar and fur type trees that are 12"-18" at the base. Not the big stuff like oak trees etc.
Are their better mauls? What are they?
What's the nice splitter if I end up purchasing one? I'm liking the electric style just from the standpoint of no motor maintenance. Plus I can split within a few hundred feet of power.
   / Wood Splitter advice #2
Try to rent the electric one for a trial. I like the idea of no gas engine maintenance. I have the Troybilt 27 ton model (gas) but only use it on the tough stuff and when my "to be split" pile gets to big.
For manual splitting I recommend the Fiskars Splitting Axe. That thing is amazing, It has almosst replaced the use of a splitting maul for me. I do 10+ cord/yr, sell some burn 6. Try to do as much manual work processing as possible. Keeps me 'keeping on' as I'm getting up there in years to the point that 'use it or lose it' is in play.
Just looked up the Fiskars splitting axe- hard to find anyone who says bad things about it!
   / Wood Splitter advice #4
I have the Fiskars X27 and also have a Swisher LS22E electric splitter. Swisher Electric Log Splitters @ Log Splitters Direct
Wife loves using them both! You will need to be CLOSE (25ft) to a 20A outlet or a generator to get good service for the Swisher. I have used it on a 100ft 12g extension, but you will likely have occasional breaker trips with that setup. She splits mostly tough hickory, so YMMV somewhat.
   / Wood Splitter advice #5
I've never used a Fiskars, but I've heard nothing but good about them from the owners.
For that wood, you don't need a beast. In the gas-engine type, a 22 ton would do you just fine.
That Swisher looks sweet, and I like your thinking on the engine maintenance. If you are going to make this a permanent thing, consider running an underground circuit out where you are splitting. I'd go that route if I could.
OTOH, I have the Huskee 35 ton with a 12 horse Briggs, and the only maintenance it has needed is oil changes. I'm still on the original spark plug after 10 years.
The Swisher looks like a nice American made product. The the Troy Built is also a good option. The electric style I was also wondering about is the flywheel style instead of a hydraulic pump.
   / Wood Splitter advice #7
I bought a swisher 30 ton 3 point hitch model for cheap before I had a tractor. I converted it to a horizontal/vertical unit with its own power source. It was a well made unit and served flawlessly splitting several hundred ricks of wood before it got stolen. I originally had it electric which had its benefits mostly quite, but it was far too much work for a non tractor owner. I put a gas Honda motor and wore earplugs. It would have worked better had I had a tractor to move wood to it. I keep hearing about having another engine to maintain. I put gas in mine and changed the oil every other year which only took a few minutes. Rolling up a cord would have honestly been more effort.
   / Wood Splitter advice #8
A small to medium gas one would be my choice any day of the week.
After splitting three or four hours it is time to cal it quits until the next day. Renting would be problematic unless you want to pound all day to maximize your time. I am assuming in N. Idaho you will burn a lot of wood so you would need one around much of the time.
Splitting by hand is not for the woosies. I hate to swing an 8 pound splitter 6 times to get through a log when it is just a matter of putting it in front of a wedge and push a handle. I bought a new 22 ton splitter in 1990 and I change the oil once in a while and the spark plug every 5 or ten years otherwise no maintenance. They work great using it as a press for straightening stuff out.
I would maybe forgo a splitter if I only had to split 6 rounds a year, but other than that I would have one. So ot all depends on how much wood you need to split. I split maybe 3-4 cords a year now, but enjoy it.
   / Wood Splitter advice #9
I split about 2 cords of fir a year on a Homelite 5 ton electric, for about 5-6 years. I've stalled it once, on about a 4 inch knot. Usually the wedge goes in about 2 inches and it pops apart. Pieces have been up to about 2ft diameter. I lift the big ones up to the splitter with the loader bucket and slide them off.
The best thing I did was put it on a table about 24 inches high. I wonder who designed them to be used from a kneeling position???
Sometimes a string, twisted piece doesn't pop apart and needs to be pushed through. Since the opening is about 6 inches longer than the cylnder stroke, you need a short pushed piece to push a stubborn piece through unless you are cutting your rounds short. Then just use another one.
On mine you can stop the retraction before full retraction and save time on the next split, if you can load it with one hand.
I have a piece of 1 5/8 tubing held on the side rails with a pair of kennel panel clamps for a wider work area. It catches most of the splits. The table lets me place some there, too, while awaiting splitting
Bruce
   / Wood Splitter advice #10
When I use to split wood I had a 25 ton Didier. I tried just about everything available that was manual but my big - 26" to 34" - 'ol knotty Ponderosa pine was just too much for manual. I burned around 5 full cords per year. There were a lot of times I wish I would have had a 35 ton splitter. The butt ends were very stringy and massive knots could bring the one I had to a full stop.
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
2008 Ford F-450 Crew Cab Service Truck (A49461)
2008 Ford F-450...
2011 BMW X5 SUV (A50324)
2011 BMW X5 SUV...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A49461)
2005 Ford F650 SVI...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
