Wood Splitter advice
/ Wood Splitter advice #21
I'd be more interested in the Super Split if it came with a log lift, and if the wedge was on the movable portion and the log stayed in place. It just seems like you have to lift every single round quite a bit high in the air up to the splitter, and then handle every single piece of wood again if you want to re-split. I think this would be fine for most people but I like to split my wood fairly small, so I re-split almost all the time. Also, how on earth do they NOT offer a 4 way option? Then I might be persuaded, but for now, I honestly just can't see how you can beat a Split-Fire splitter. But then again, they're what....double the cost??? I'm sure that's the reason you don't see a lot of them.
/ Wood Splitter advice #22
I burn about 2 cords a year, and my parents burn another 2 chords. I learned a long time ago that if you are going to have a small engine, it has to be a Honda. Nothing else matters, get something with an engine that starts easily every time, year after year. My splitter is a Troybuilt that I bought from Lowes with the Honda engine. I think that most of them in the same price range are close enough to not matter except for the engine.
/ Wood Splitter advice #23
I agree! And get the GX series!
/ Wood Splitter advice #24
I have the same splitter with the Honda. I have had several mowers with Hondas - always start 'first pull'. Nodt that splitter. Takes at least two pulls and the rewind spring does not have enough tension. On a warm day it will rewind, on cool or cold days I have to use a screwdriver to rewind it. I should take the starer apart and add another wrap but my experience has usually wound up with the coil spring all over the shop.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
(1) UNUSED 9.5-24 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED 9.5-24...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
Caterpillar 16G Motor Grader Parts and Service Manuals (A63117)
Caterpillar 16G...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
2020 ISUZU W4500 4X2 S/A  16FT BOX TRUCK (A59912)
2020 ISUZU W4500...
