Disc Harrow Disc or plow recommendation?
/ Disc or plow recommendation? #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
Guys, I'm wanting to get an implement for breaking ground behind my Kubota L3301 (32hp).
I don't know anything about plowing or disking.
The ground I want to work I've cleared with a grapple, back blade, box blade, and brush hog. Less than 3 acres.
Its SE OKLA, rocky as ****, thin dirt, and was bulldozed flat around 1997.
I had thought a two bottom plow but reading through the past posts, maybe a disk setup is better for me with my rocky ground?
Not really sure what to grow but want to grow SOMETHING beside briars and red cedars! Maybe a deer plot or some kinda low maintenance vegetable to start with.
It's not perfect but not all garden plots start out good.
Vintage implements is fine for recommendations also. I enjoy bringing them back to life.
Never farmed and want to do a bit as a learning hobby. I'm attached to the land I have and don't want to move but do what I can with what I got. (I mean the land. I can buy the toys I need. Just don't want to buy the wrong thing or overbuy.)
/ Disc or plow recommendation? #2
No, a Moldboard Plow or Disc Plow (which is NOT a Disc Harrow) is better for initial turn of soil. Unless really prolific, rocks will not dull a plow, unless plow is pulled for miles. Plow will disrupt roots, which a Tandem Disc Harrow sized for your tractor will roll over.
A 12" moldboard plow will cut a furrow 6" deep and pile turned soil next to the furrow 6" high.
You will need a Disc Harrow to succeed the plow, to lower plow furrows. The first pass with the Disc Harrow have the gangs set at an aggressive angle. The second pass have the gang angles set two increments less aggressively. The goal of harrowing is to leave a smooth seed bed.
THREE LINKS:
http://www.tractorbynet.com/forums/attachments/308251-disc-harrow-selection-18-45-a.html?highlight=
http://www.tractorbynet.com/forums/...ing-three-point-hitch-mounted.html?highlight=
http://www.tractorbynet.com/forums/...oard-plow-wisdom-farmwithjunk.html?highlight=
A Spring/Summer food plot, succeeded by a Fall/Winter food plot, succeeded by a Spring/Summer food plot, each plowed into the soil, will do a lot to enrich soil and reduce weed seed bank.
/ Disc or plow recommendation? #3
Take some time and visit your neighbors. Don't puke your money on the junkie down the street. Your neighbors can tell what works best in your area and then you can spend your money wisely at the neighborhood junkie's place....... Now how do you suppose I know that?
/ Disc or plow recommendation? #4
Disc Plows: Google
There should be used Disc Plows available in Oklahoma.
/ Disc or plow recommendation? #5
We used a 2 disc plow when we lived in OK. Discs are less likely to get hung up on something and break something.
What would be really useful, if they made them for big tractors, would be a rotary plow off the PTO. Had one on my Gravely. Great for breaking up ground.
/ Disc or plow recommendation? #6
With thin, rocky soil, you don't want to use a moldboard plow. That will just flip the soil and bury the good stuff. I'd use an offset disc with an attached harrow of some kind (spike harrow, tires attached to a piece of chain link fence, etc.).
Good luck.
/ Disc or plow recommendation? #7
I see Monroe Tufline makes an Offset Disc which a 2,750 pound Kubota L3301, with 4-WD, should be able to pull. Peculiar that Tufline's web sites specifies neither 'Offset' widths nor weights, only lengths.
TLO Series Offset Lift Disc Harrows | Tufline
/ Disc or plow recommendation? #8
Forget the plow and harrow and all that stuff. It's too much setup work and they will just get in the way 99% of the time and rust in the rain. I would go with a simple Dearborn/Pittsburgh cultivator (or similar) like this one that I rebuilt and now use as I am telling you to use.
Here it is
http://www.tractorbynet.com/forums/attachments/312434-1950s-dearborn-cultivator-find-rebuild.html
And here's my rebuild thread above.
I'm as much as a plow and tillage guy as the next but multiple passes with this will do a better job and you don't need 30 acres to learn the drill. There's no dead furrow to contend with and no trying to smooth clumps of dirt and debris. Each pass makes things smoother. It will pull up some rocks but pick them up and call it good. These are the perfect garden implement and there are zillions of them around. Use it with 1 3/4" or 2" straight points and not shovels. Piece of cake and it's way more fun to use.
Here it is
So with this, a cultivator is all I probably need?
Is this close to being a "chisel plow" which I see some of around me?
What width should I be watching for?
Thanks.
Disc Plows: Google
Thanks. I found a YouTube video from that showing a disk plow working. I've never seen one of those and found it interesting.
/ Disc or plow recommendation? #11
Plows, whether moldboard plows, disc plows or chisel plows are primary tillage implements.
Chisel plows, in particular, require pretty hefty tractor weight and horsepower to pull through soil. Chisel plows are conservation plows, intended to leave around 15% of verdure growing, to protect field against rain and wind erosion.
Buckeye tractor makes a relatively light, 3-shank chisel plow available with and without spring protection.
Buckeye Tractor Online Catalog Page 18-01 Chisel Plows
HISTORY: Graham-Hoeme Plow ASABE Landmark No 38 - YouTube
Cultivators and Field Cultivators are secondary tillage implements, designed to work already plowed/opened land. Spring loaded Field Cultivators can be considered LIGHT DUTY, secondary tillage chisel plows. Field cultivators are secondary tillage conservation plows, intended to leave 'some' verdure growing to protect against rain and wind erosion.
Cultivators penetrate 3" to 6". Primary cultivator purpose is to disrupt weed growth. Cultivators have SHOVELS.
Field Cultivators penetrate 10" to 12", more for ripping/aerating soil. Field Cultivators have (chisel) POINTS.
MANUFACTURER: Dirt Dog Manufacturing
Field Cultivators require five tractor horsepower per shank.
/ Disc or plow recommendation? #12
Thanks.
Well, it's all I would need based on decades of figuring this out. These cultivators are from the 1940's to 1950's and there were untold zillions of them made to go with the 8n's and similar sized tractors revolutionizing agriculture and the family farm. This is the type of implement that took the family farm from the hand hoe to mechanized thinking. It did a remarkable job of that and that is about the level many are at when first planting a large garden or an acre of something. Almost all of these are 7' 6" and sell for several hundred $$ at auction. The spring shank ones, like I have, work best and they originally came with 11 shanks, so get them all.
I've bought, sold and used a number of plows, harrows and such over the years but keep coming back to the way that has worked best and been the most efficient. The simple cultivator. To start with more complex ideas like a plow or this or that right now would take hours of education and experience plus much second guessing and fact-checking while you learn. Save that for winter and the time for the family.
The harrow shown, yes, is close to being a mini chisel plow (if you put chisel-like points on it) after you make multiple passes but will leave the ground smoother with successive passes. It will also pull up rocks that you will need to pick up but will make that task easier and will be more gratifying to use. In the end, you'll have to use what you think you should and I'm just offering my experience and what I have learned.
You will be able to satisfactorily pull this with your tractor if you take it easy at first.
EDIT--Any other simple cultivator would work as well.
2018 Kubota RTV 900 4X4 (A62613)
2018 Kubota RTV...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
