I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #51
One of the best indicators I've seen is a piece of steel about 6" long welded on the top of the bucket parallel to the bottom.
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #52
With a torpedo level strapped to it! :)
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #53
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #54
That would be better, but it wouldn't survive long.
Whether it would survive or not it would be tough to read anyway.
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #55
Pretty sure Pilgrim was joking. ;)
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #56
Yes I am sure he was.
I was thinking that some folks might want to do that though. Funny, visions in my head of someone getting on and off the tractor to see if they had the blade level.
Richard I am pretty sure you get on a tractor and just drive, and adjust the fel bucket as you see fit.
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #57
Bucket level is really an improper description, bucket angle is what a loader technician like me is looking for. With just a 6" flat bar on top of my bucket for quick simple easy bucket angle reference works the best for this loader technician.........
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #58
I could care less about "angle". I want to know when the bucket is level in relationship to the tractor. I'll adjust from there. :)
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #59
locate the bucket flat to the ground. locate the connection that tilts the bucket. paint a line across the junction.
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #60
True, in another thread some troll went on and on about "level" not being correct term if tractor was not on level ground (up hill, down hill) ... Angle probably is better temp as it indicates relationship of bucket lip/bottom to "plane" of which tires are on....
Anyway an angle (level) indicator has help me quit a bit in may FEL operations....
Dale
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
Kubota M5-111 (A53317)
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
DEUTZ MARATHON...
John Deere 1025R (A53317)
John Deere 1025R...
