Convert/Redo hydraulic snow pump
Status
Not open for further replies.
/ Convert/Redo hydraulic snow pump #1
fitterski
Gold Member
Nouvelle, QC
1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
I put this into service Xmas 2009 and it is now starting
its 8th season of abuse. By abuse I mean everything from
design to the blower detaching, breaking the electrical
harness and running away downhill into a ravine.
[1st post utube link not allowed]
# is zsgvwMYn0N0
But it works, and amongst *git-er-done* folk it's pretty
hard to argue with that!
Before digging into the beef I'll just mention that
my driveway/runway is 3000 feet long so that all
snow removal operations are strictly mission critical.
Not only must everything start and work in any conditions,
once going any midway hangup where in addition to
mission failure I also block the road can be very
expensive. Digital controls are because of this out
of the question. Instead of failing DOWN to total
service denial (my 2008 Tundra just did this recently)
good digital systems fail UP to a passthrough circuit
hardwired to protect fallback to purely mechanical
control. Unfortunately few consumer-level digital
systems are of this level in 2016.
So, on with the original main topic:
Problem is I want more power and because of weight
constraints that means going to the originally
dropped hydraulics option; namely, a separate engine
and pump powerpack and a hydraulic motored blower.
Another reason I want to maybe sidestep to this
approach is that I'm getting on in years and I may
have to backlevel to a truck mounted system. My 2008
Tundra will be put out to stud in a few years and by
then I want to have the new system proven, worn-in
and ready to be transplanted.
What I have works fine, the design objective was to blow
4-6 inches of dry snow 100 feet laterally at 15 km/h or
so. However wet snow isn't dry and sometimes there's a
lot more that 4 inches of it. Brilliant observation #2
is that the 8 years have taught me that when you fall
behind the curve then only one and no other solution is
necessary: not just overpowering but OBSCENE amounts of
overpowering. Dry snow gets pulverised to an undriveable
consistency around 150 feet per second which does not
apply to wet snow so I'm thinking 600rpm with torque
autoincreasing virtually unlimited on demand and an
additional spoolup option to around 1000rpm. I could
also drive the fan at 1000 all the time, and BTW the
proper name for a beast of this nature is not a snowblower
but a snow-pump, some people actually test theirs by
driving them into the sea ...to a stall depth of a few inches.
So the new design objective is to throw up to 8-9 inches
of wet snow at least 100 feet vertically at a similar or
15-20 km/hr clip behind a 7-foot wide auger.
The good news is that there are very few limits, I want
no less than 300hp on tap and the hyd. motor putting out
major fan torque between 600 & 900 rpm with no gearbox.
A gearbox IS possible but why bother when I can drive
the auger with another smaller high-torque motor and
simplify things in the process? Besides, a gearbox of
this capacity is 250lbs-$3k easy.
All suggestions are welcome, the first and foremost
question being the pump/motor combo size/type. I can
find and engine later, I can design a smaller/larger impeller.
Is the service longevity of piston type hyd. motors
good?
tia
If I do the hydraulics thing than I have a few intial notions: the motor would be a Duramax LMM, the pump about 12 cu-in with a nominal system pressure of 2500psi @3000rpm drawing 285hp which should be good from that engine. The motor end is where a LOT of losses show up so with margins still protected and strictly on paper I figure 36 cu-in, 945 torque @1000rpm, down to about 180hp. Such a motor may be just a wet dream weight wise, nor will this give me 100 foot vertical throw but maybe half that. Getting 100 would require a non-hydraulic direct drive (current setup) which does remain one option for the time being but I may have to increase reduction to 3:1.
The current outstanding question is what is the limit lateral load on the flywheel of this engine?
/ Convert/Redo hydraulic snow pump #3
For hydraulic drive have you considered going to higher pressures?
Rexroth makes fixed displacement A2FM motors in 250 cc, 355 cc, 500 cc. All of these will operate at 5,000 PSI and speeds up to 2,000 RPM depending on the size. They also make variable displacement A6VM motors in the same displacements for use if you wanted two speed option for wet vs dry snow.
At 285 HP you can drive a pump to provide around 85 GPM @ 5,000 PSI. a 125 cc pump at 2,500 RPM would produce 82.5 GPM. Depending on the brand of pump you may be able to get manual displacement control Vs electric.
I would run this in a closed loop circuit to reduce the reservoir size and limit losses from valving.
No idea on the Duramax flywheel loading.
/ Convert/Redo hydraulic snow pump #4
That's a cool machine. Maybe you should think about an old Unimog. Nothing digital. Just to clarify, are you serious about throwing wet snow vertically 100 feet? Or did you mean laterally?
Thanks for responding oldnslow, I ain't so young or fast any more myself :)
5000 psi scares me, a pinhole leak can kill you at that pressure and DIY 300hp ANYTHING is a very violent environment. I may eventually have to re-evaluate but for now I'm still crunching the very basic formulas (been like 50 years since a few rudimentary air-force lessons & I've never touched hydraulics since!).
From what I see so far is that axial piston pump/motor is the most flexible and would easily accommodate my numbers (rpm-pressure-volume-torque). A closed system would save weight and since it would be for a SNOW blower, thermal dissipation should be OK although that may still require a radiator and THAT would be simpler with an unpressurised reservoir. I think I have already seen pumps in the 12 cu-in/2500psi range, the 36 cu-in motor not yet. It may bee too costly or inexistant.
Until now I had envisaged only fixed displacement pump/motor planning to modulate fan rpm +/- 600-1200rpm by changing engine/pump speed. I kind of do that now with the existing rig. The thing is I still have a LOT of learning to do. That 500cc @ 5k psi might be the one for me, I sure am going to bookmark it.
Some of my 'fishing' notes:
I already HAVE the 426 and giving it something to do in the winter actually helps to keep it oiled as it were. The initial idea was to have a radio controlled system that allows me to drop the blower and work with the loader at will. That, alas, flopped because the 24 channel radio set I bought from China picked up stray signals and engaged the starter while operating, twice! So the short of the long is that I scrubbed that idea but that's how it all started with the Cat. Also, there ARE plenty of stock machines, used even at very good prices but none of them are designed to toss snow very far and in my case that's imperative. Some very big industrials can do it but those cost more than my house.
As for the 100 feet I do that now, horizontally, downwind :) The vertical idea came after a few arguments about the math required so I then decided to simplify and talk vertical only! Actually I'd love to see a new sport come out of this, it would help pioneer some interesting mechanical solutions .....like THIS guy I just spotted today
Homemade truck snowblower (chevrolet Tracker) - YouTube
cannibalized tracker turning the blower with the fwd-driveshaft while a 3-holer in the trunk moves the wreck around :) :) :)
Hey, is that a twin-fan blower in your avatar? Is it yours? Looks like it's handling a mouthful easy. I'm lookin', it so happens that a fan is about he same weight as an auger. Are they driven by one hyd. motor?
About the digitals, if I were to go strictly mechanical I was looking at a cummins 6BT, 200 horses would be ok. With hydraulics the losses add up so I need double at the pump, The Duramax is a very tightly engineered bull, someone I know is putting one into a small airplane. What I've heard from the grapevine is that up to the 2008-2009-2010 production year the last of those models the LMM can still be run with a more or less stock engine-control-module and some wiring work. I had also looked at the Cummins 5.0L-v8 but _ain't looking at that no more_
/ Convert/Redo hydraulic snow pump #8
Fitterski,
FYI: Rexroth also makes those motors in a 750 cc & 1000 cc option. Price may be an obstacle though.
Can you use a lower RPM and larger diameter fan to get the tip speed you require? From my feeble old memory our Gehl hi-thro silage blower had a 54" diameter fan running at 540 RPM and you could easily fill 80 ft silos with 90 HP tractor.
Fitterski,
FYI: Rexroth also makes those motors in a 750 cc & 1000 ...
The only comparison i can make is to what i can do with snow, with what i have. I don't have a mental handle on or feel for silage weight & mass. When i first started lotsa folks insisted that 540 rpm was "it", but that is only because most pto's are 540. I now run my 36" fan at up to 1000rpm, that's max with the 2.5:1 gearing due to approaching engine redline. It is very finely balanced and I think I could take it up to 1200-1400 but wouldn't wanna risk eating a mailbox post at that speed. The theoretical high limit would be trans sonic probably around 2200 rpm with a 48" fan. At that speed wearout would be a concern, extremely fine balancing also, and the snow would have to be fed very evenly. I don't know off hand the hp of my Deutz 4-holer, it's around 65hp and that starts huffing/puffiing quite easily. I "could" make another one but wouldn't want to go far past 40" because then I'd start getting into a dual auger box size and the associated weights.
My attack will be spread over 4 stages: first I'm going to try the engine as-is on my rig. I only need to respect the flywheel lateral load limit once i find it. I'll see how the gearbox can take that torque, it might just break. The present fan running maybe 1200 should already be quite an improvement. Step-2, I'll have to decide if I have enough horses doing nothing and maybe make new 40"-42" fan. The 3rd step will be the decision to go hydraulic, the 4th to move it all to another platform.
I looked at that 500cc motor and almost fell out of my chair when I saw the weight, 300lbs! The pump would probably be similar, plus a possible reservoir, plus the 150 lbs extra that the Duramax brings and I would be in a corner to make all that work on my loader bucket so the decision to go hydraulic will most likely be a concurrent one to change platform.
I could also try for a 70% capability reduction but don't really have a good engine in sight for that role at around 750lbs, plus the fundamental approach seeking to have 'obscene' amounts of power in reserve isn't really aiming to go with less :)
/ Convert/Redo hydraulic snow pump #10
That is a twin fan, made by the German company Beilhack. They are PTO driven. Engine for the blower is a Mercedes OM321A, 110 hp. I use this a few times a winter, not a lot.
/ Convert/Redo hydraulic snow pump #11
How about a 4x4 truck with a diesel engine in the bed and a chain drive to a shaft under the truck body to the front blower. You'd have to weld up a chain housing with pillow blocks and run the chain in oil. More efficient than hydraulic drive and a lot cheaper. Put as much horsepower in it as you want. Would be fun to build. Hardly snows here though.
/ Convert/Redo hydraulic snow pump #12
fitterski,
I also have no clue on the weight of silage or haylage Vs snow. Just trying to give you some idea on fan size & speed for an application throwing something into the air. for reference I could unload approximately 2 ton/minute silage with 90 HP.
110% agree mechanical will provide the best performance and least cost.
Bigdeano has an interesting concept if you can get enough lift height.
Ever since having gone to Gates cogged belts I have totally left chain drives behind. For one thing they have a beauty of a gearing simulator on their web site that SHOULD be he envy of every machinery or hydraulics manufacturer. When I was first designing the existing horror it came out with a 1-1/2 inch suggestion for the HP, which sounded well, how could I express it, like pink panty hose, you know? So I phoned one of their gurus and got the answer more or less: "look we garantee it'll do the job, of course if you want to just forget it for the rest of your life take a 4" job good for 600 hp and you will never again have to bother with it. THAT's exact;y what I did I have NEVER again bothered with it :)))))
Because the larger fans, 48" needs a driveshaft at least 24" above the ground, that poses problems of its own. But I also have a retired Jimmy 4x4.... so the stage-4 build might just go in such a direction.
fitterski,
I also have no clue on the weight of silage or haylage Vs snow. Just trying to give you some idea...
I realize that & thanks for the idea, I sometimes come across like a stuck-up turkey, sorry :)
2 tons a minute that's not bad at all! I've always eyeballed snow as so much per second and have thought along lines of maybe 50lbs/sec or 3000lbs/min so it's ballpark. But I never really calculated it (yet). That ballpark compare also jives with the relative horsepowers so at least it must be pretty proportional. Don't know what Bigdeano is, google hits on nothing.
/ Convert/Redo hydraulic snow pump #15
You have nothing to apologize about. To easy to get misinterpreted on these forums or life in general anymore.
bigdeano was the person that posted about putting an engine in the back of a 4 x 4 and front driving the blower via chain drive.
For the record I was figuring you would put the dura-max engine in the bed of your Tundra to drive the hydraulic pump. I have never seen the video of what you have today. Shows as an invalid link on my screen.
Another off the wall idea from a darn Yankee :) Do you have larger farm tractors in your area with front PTO option like they have in Europe? If yes possibly front mount a blower on one of them.
oldnslo, i was not allowed to post links when i had just joined so i worked around that by posting only the y-tube #. The full link should work
Deutz powered JD Snow Blower from Hell 29 - YouTube
I built this for xmas 2009, it's doing it's 8th season and it looks like a big one already. We have 10-15 storms generally, we're already on #6 as i write this :)
My Tundra idea might be wavering, it's a big truck that is less maneuverable. Plus it's an automatic and although i just bought it last summer and am not that familiar with it i already don't like Toyota's way of doing things. For example I may have reason to wanna instantly floor it and spin all studded wheels at any time. IT will not let me do so, etc. etc. So a new flash-in-the-pan is taking form: i have a retired Jimmy 4x4, and even better I'm already casing a real jeep (cursing the day i gave my 4x4 cherokee away). The plan might be to swap a front axle in the back for 4-wheel drive AND 4-wheel steering, put engine and pump on rear frame extension, blower in the front. Geometry permitting maybe do without hydraulics.
All begins however with the engine on the current platform, that's where i might have it ready to prove itself next season. After that....
I've been tinkering with fan tip speeds and such, here' s the results
I don't understand how variable pressure pumps work i.e. just how that pans out in practice. The last 'notes' entry on the attached image is what I would consider a pro solution but have no idea how I would accomplish it. Another possibility (if using a Duramax) would be to also use the 6-speeed Allison connected directly to the fan, giving a very wide range of control.
/ Convert/Redo hydraulic snow pump #18
I don't understand how variable pressure pumps work i.e. just how that pans out in practice.View attachment 494358
Variable pressure or variable volume? Variable volume pumps can be controlled via pressure. These pumps would have a control that senses pressure and at some preset point the control would start to reduce displacement to maintain a constant pressure.
If using a closed circuit pump like a hydrostatic transmission you can proportional displacement with pressure override. This allows you to set a displacement and then at a preset pressure the pump will start to reduce displacement.
On both of these example the displacement will increase if the pressure falls below the set point of the control.
Do these definitions help at all?
What caught my eye was variable displacement in a catalogue. Thanks for the answer but for now it's over my head, kind of a paradigm shift to start thinking in terms other than gear ratio & torque*rpm/52xx :)
I am now committed to the Duramax diesel, just struck a deal on one. It ain't delivered yet but I should have in 10 days or so. This engine will give me all the power I could ask for and then some with 700 ftlbs of torque on tap @ 2200 rpm I would still be in the comfort zone with 250 hp easy for a pump at only 600 rpm above optimal torque.
What I had in mind initially was to use 3* more volume @ 1/3 the rpm at the motor end as a dummy's way to torque convert. I will have to revisit this topic later maybe, I think I posted prematurely. Depending on fan size I may not wanna go above 700 fan rpm so the 3 to 1 ratio might still apply at a bit less power.
Concurrently if there is a way to run the fan at 700 rpm with a much lower engine (pump) speed when there is little snow then it would be more elegant to do so and spare the engine. I 'think' (in hydraulics I'm not qualified to think) that some variable displacement pump/motor and governor combination might hit just what I want.
A closed circuit it will be, I have not seen any hydraulic snow blower with a reservoir yet.
/ Convert/Redo hydraulic snow pump #20
You still need a res with a closed loop system, about 1/4 of what you need with open but with the correct coolers you don't need much. For a example the system I usually build for a top drive is 120 Gpm at 5000psi and they happily live with a 25 gallon res and the correctly sized cooler running 24/7. Remember the oil into and out of the res is controlled by the size of the charge pump. I run a 2.4 cu.in. pump and that gives me just under 25gpm. For almost any high horsepower application piston units are the way to go. We average 4-5 years out of a 25 series Sundstrand pump and 2 years out of the drive motors. only because of the high surging with drilling. CJ
Status
John Deere 5090GN (A60462)
John Deere 5090GN...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2009 John Deere 1770NT Planter (A63111)
2009 John Deere...
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
