Oil & Fuel Ford 5000
   / Ford 5000 #1
Fixmaster
Peterborough ont Canada
Ford 5000
I'm having a fuel related issue , it's an early 60 ish Ford 5000 diesel , starts and idles great , will pick up 200 rpm at full throttle , doesn't change when linkage is moved from idle position till full throttle position
   / Ford 5000 #2
Bummer.
Hopefully one or more of the experts on here will chime in. Your thread title probably isn't going to draw much attention though.
Welcome to TBN!!!!
   / Ford 5000 #3
Check fuel flow from the tank. When was the last filter change? Once good fuel flow has been established from tank through filter if the symptoms persist, replace the transfer pump.
   / Ford 5000
You don't think it could be injector pump ??
   / Ford 5000 #5
From memory the 5000 didn't have a transfer pump these were gravity fed from the overhead fuel tank. Could be something in the throttle mechanism in the injector pump but I do not have a clue how that works.
   / Ford 5000 #6
Many 5000's had a Minnemec inline IP with a lift pump attached. The lift pump is easily replaced and is subject to both diaphragm and check valve failures.
   / Ford 5000 #7
If its a Simms inline pump, lines come off the pump going up to the injectors in a straight line..
There is a side cover on the pump, remove it and work the control rack by hand.. its probably sticking..
You do know it takes oil?? Just regular engine oil.. fill on top, drain on bottom and full screw on the side..
I think you'll find its full of gunk..
The lift pump is bolted to the side of the injection pump.. about $40.00 anywhere online.
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
2019 Range Rover Super Sport AWD SUV (A55853)
2019 Range Rover...
UNUSED FUTURE DIE-CAST TOY (A57192)
UNUSED FUTURE...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
2019 Bobcat E32i Mini Excavator (A55851)
2019 Bobcat E32i...
UNUSED RAYTREE RMSG29 29" HYD STUMP GRINDER (A57193)
UNUSED RAYTREE...
