I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #1
ayrport
ayr ontario canada
B6000
hi there
i would like some idea's how to tell if my non self leveling buck is level? im new to the tractor world and i seem to never have it level.
it is either digging in or tippedd up too much for what i want.
thanks in advance jim
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #2
Search for bucket level indicator
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #3
That^
Or lots of practice:eek:
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #4
I had a bucket level indicator rod,,, and removed it!!
The indicator only was correct,,, if,,, the ground is level,, that never happens.
I just learned how to "know",,,
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #5
If you have a float setting for the loader arms... on flat ground with the bucket cutting edge tipped up back up, with the loader arm in float, roll the bucket out and watch for when the loader arms start to raise, at that point the bucket is close to level.
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #6
Practice. Sometimes you want that bucket digging in the ground, others not. Why are you going forward with the bucket level on the ground? If you're scooping you want a little up tilt, if you're pushing snow you want a little down, very few situations call for dead level on the ground.
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #7
I have a bucket level indicator and painted the position on it when it was level on level ground and then I know how I need to compensate for the terrain or activity. I find it very handy!
   / I NEED A TIP HOW TO SEE IF MY BUCKET IS LEVEL THE GROUND #9
I like the bucket indicator on my L3400, it has a 6" long steel plate on top of the bucket, so what ever angle that is, the bucket blade is, I reference that everytime I use the FEL. I like it better then the rod set up, I'd be catching tree limbs and brush all the time with that, after I got out of the woods the rod wold be in the shape of a S.
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2001 New Holland EC215 Hydraulic Excavator (A55973)
2001 New Holland...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
