Log Splitters
   / Log Splitters #41
I grew up with a sledge in my hand from the time I was around 8 as did every one I went to school with. No, I do not remember ANYONE splitting with a sledge in such a stupid fashion. One uses a sledge with a full length handle and really swings, notd just tap, tap, tap. The stuff he is splitting would just fall apart with a fiskars.
Agreed! I'd split that with one swing of my Monster Maul!
Actually, my 8 pound regular maul would probably do the trick with one swing.
   / Log Splitters #42
I do around 12-14 cord a year (use 6, sell the rest) and still do 90% of the splitting by hand, wedge/sledge/fiskars/maul. I have the Troybilt splitter but it only sees the knots/crotches/twisties.
It's amazing what a Fiskars splitting axe will do with so little weight. It's a whole lot less work swinging a Fiskers as opposed to a sledge or a maul but I leave most of it up to my splitter. Cutting and splitting wood still adds up to work no matter what you have. Even using a chainsaw and splitter requires some work on your part.
One cheapie tool that took some of the backbreaking bending and stooping out of it for me was a simple pickaroon (hookaroon) so don't forget that some hand tools can still make a big difference, even with a splitter. 1482_75000_p1.jpg
  • Council+Tool+CNC+150+1-1+2+lbs.+Hookeroon+with+36++Curved+Wooden+Handle_S.jpg
   / Log Splitters #43
I bought a dirty hand 27 ton. The 6 horse Kohler that came on it struggled on some of the really knotty stuff. Would almost die when the pump kicked down a stage.
Cured the Kohler struggling issue though. Had a 4 hp yanmar diesel sitting in the garage and it bolted right into place of the kohler. With the diesel, it just grunts and goes. And doesn't know the meaning of knot any more either :cool:
   / Log Splitters #44
One cheapie tool that took some of the backbreaking bending and stooping out of it for me was a simple pickaroon (hookaroon) so don't forget that some hand tools can still make a big difference, even with a splitter. View attachment 493040
Amen to to the hookeroon. I resisted buying one for years thinking $60 was too much for a simple "nail on a stick". I finally succumbed and my rear is still sore from kicking it because I waited so long. Anyone working around firewood and doesn't have one is handicapping themselves.
I went one better and built an 8' one out of a closet pole, a plumbing compression fitting and a piece of !/2" all thread. Haven't climbed into the bed of the pu since to unload.
   / Log Splitters #45
Yeah, I posted that video just for the general principle. I've split lots of cottonwood logs with a wedge and sledge and they were much tougher than the video shows. I did learn that splitting those logs frozen was much easier. The Troy built splitter I have now is like a dream machine. 🙂
   / Log Splitters #47
I've narrowed it down to these two.
http://https://www.lowes.com/pd/Dirty-Hand-Tools-27-Ton-Hydraulic-Gas-Log-Splitter/1000096980
or
http://https://www.lowes.com/pd/Champion-Power-Equipment-25-Ton-Gas-Log-Splitter/1000126583
I see good in both and also some bad. The Dirty Hand some say runs really hot. Not too many reviews on the Champion. Reviews are mostly good on both. I burn roughly 6 cord a winter and will split year round. I'll end up getting it within the next couple weeks. Just thought I would ask you guys if you had experence with either. Thanks.
Here's another vote for the Dirty Hand Tools. I have had the DHT 22 ton for two years now. Wouldn't trade it for anything else. It has a really fast cycle time. (amount of time it takes to extend the ram and bring it all the way back) Much faster than many other splitters, even those with larger engines. And, I have yet to find a piece of wood that it won't split. I burn mostly red oak.
The only minor problems were a couple very small hydraulic leaks. I removed the fittings, applied pipe dope, and screwed them back in. That's it.
I've never seen the Champion, but I can vouch for the Dirty Hand Tools.
BTW, I saw an earlier comment in this thread that suggested the DHT was another brand with a different paint job. DHT is a manufacturer and is located in Colorado.
   / Log Splitters #48
Last year after much investigation (1 year) I had decided on the Northern Tool Northstar 30 ton and was waiting for a good sale- which never happened. At the end of the season it still had not gone on sale yet and I stumbled across a seasonal closeout sale at Lowes for the DHT 22 ton. DHT was my second choice, albeit a 27 ton model, and the price was good enough for me to give it a try, even though it was not as sophisticated as the Northstar and was only 22 ton.
Having split a lot of wood since the fall and it has turned out to be a decent splitter, with the optional log cradle a must have. But with my red oak and white oaks, 22 ton is a bit small and struggles more often than I like. In hindsight I should have gone with the NT 30 ton and a 4 way splitter head.
Champion is a no-go for me.
   / Log Splitters #49
Did you buy it on line or through a dealer?
I bought it from the local hardware store, it was a rental. They told me it had been rented 5 half days. It was like new and I wore the paint off of the beam. I trust the guy.
   / Log Splitters #50
I have a 42T Northstar. Great splitter. I added a catch table and have split many, many cords of wood over the past 7 years with no issues. They are a very good quality product.
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
