I (narrowly) averted a multiple roll rollover crash in the tractor the other day.
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #31
This is very typical of the R4 industrial tires. They are the WORST tire I've EVER used in snow and especially ice.
I took a tire cutting tool and "cut" my R4's and they are now literally 2-3X's better in snow and ice. I can't imagine using an Industrial tire on snow and ice ever again without cutting them.
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #32
Smooth ice wet snow on ice not R4's friend w/out chains,rear scraper does come in handy when traction control broken on slope.
Dang glad good ending for you.
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #33
I'm planning on grooving my tires this week. I put truck tire chains on my small front tires, but don't have any for the back. Did you just do one groove per bar, or did you cut them in any other locations?
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #34
The rears I just cut 1 groove per lug. I started in a little bit from the very corner thinking it would keep the lug stronger on the edge, but I think i'd cut it all the way to the edge if I did it again.
The fronts I cut at roughly 45* angles and cut each lug twice making like 3 sections. That was a HUGE improvement, because the R4 has absolutely NO side traction at all. They are like slicks. After cutting them, it does more work in 2wd than it ever could before in 4x4. The slipping and sliding like a fool is done, and its not an embarrassment to drive in snow in front of people now. The main thing is the wheel hop associated with spinning them in 4x4 is reduce now because they rarely have to spin unless the snow is really deep.
Before I cut them on my 2520, I hooked it to my dads Polaris Sportman 700 ATV and we had a tug of war on my snow cover gravel driveway. That Sportsman weighed maybe 800ish lbs, and I had over 1,000 lbs in my ballast box alone and in 4x4 he drug me around with ease. After I cut them we tried it again on the snow covered driveway and when he staying in 4x4, I could drag in around in 2wd like he wasn't even back there. So, it made one **** of an improvement.
I just traded my 2520 for a 2720, so I need to cut these new tires. I had it out today and it really Pi$$ed me off in the snow, so I put it away before I got too mad. used my ATV for the jobs and never looked back.
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #35
Good information, thanks for passing that on. I'm a little reluctant to try it, but after a little googling, I decided to use my chainsaw for cutting the grooves. Wish me luck!
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #36
Good luck sounds sketchy to me. Hope it doesn't become expensive.
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #37
It be nice to see some pictures of what you did.
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #38
Yes, I hope that also.
I've got just the saw for the job, though. A nice little 40cc Dolmar with a 12" bar. Real sharp chain, high RPMs, and keep my fingers crossed (and out of the way :)).
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #39
Yup. Can't keep your fingers crossed if you only have one! Lol
/ I (narrowly) averted a multiple roll rollover crash in the tractor the other day. #40
Operating a Chainsaw ON your tractor? I'd opt for another tool. Seriously.
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2022 John Deere 3025E (A60462)
2022 John Deere...
2024 JCB 35Z-1 (A60462)
2024 JCB 35Z-1...
2461 (A58376)
2461 (A58376)
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
